Yokomo MR-4TC SD
#9616
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by Matt Howard
Korea is fine, but the nearest track is 140 miles away and the bus schedule will make it a two day event if I do go.
#9617
Originally posted by johnbull
Paul.
I think that pillow ball comes with the pack of plastic shock parts.
Yoke make some smart alloy ones you may be interested in.
How's RC racing in Switzerland.
Paul.
thanks for that... this is parts tree "A", and that's indeed the one whose part number I'm looking for... So if anybody has the part number, that's be useful... I'd really like to use the plastic parts rather than alloy, because it's easier to compensate slop that way....
part number, anybody???
Thanks,
Paul
#9618
Chassis conversion for Yokome SD/CGM
Just thinking what other chassis conversion can we get for SD/CGM.
Is it only just the following:
Rayspeed
Fibrelyte
Rayspeed
Fibrelyte
#9619
Re: Chassis conversion for Yokome SD/CGM
Rayspeed
Fibrelyte
Rayspeed
Fibrelyte
#9620
Hi guys, i had a yoko SSG SD a while ago, maybe a month after they came out but sold it and moved on to the xray.
but tomorrow i will be picking up another one again (maybe monday)...
seen as though its a long time since i've had one..are there any recent tips that i should keep in mind....or any new parts out that make the car quicker (and don't say chassis conversion kits like the rayspeed etc )
thanks
Matt
thanks
Matt
#9621
Raving-Monkey,
I dont think there are any necessary parts for the sd. It seems to be still awsome out of the box. I just recently bought a cgm conversion and cant really tell if it was worth it but I havent had a chance to try it on carpet yet. There are some things that the ssg chassis owners are doing such as using countersunk screws on the upper deck and middle chassis plate instead of the button head screws to keep the chassis from tweaking. Just get some springs and you are all set.
Blake
Blake
#9622
i have still got the tc3 spring kit i had from the tc3 (before i got the yoko) and i also used them on the yoko.
i remember when i had the yoko, i took the centre brace out as i felt it drove better without it, felt a bit smoother...but that was on low-med grip carpet, we have some new carpet at our club now.
for the batteries....tape or battery bar?
i used to use the battery bar but now i use tape on my 12th it seems much better than a battery bar, holds the batteries better...so which is best?
#9623
#9624
Ok, what about the rear shock tower on the front?
#9627
Mmmmmm........
I'm putting in the electrics now, (after having the motor cam machined out to take 540's) and low and behold the Yokomo pinions don't fit in the car.
I got 35-40 tooth Yokomo pinions and only the 35 fits because on the 36-40s the shaft of the pinion (where the grub screw goes) is to long and the pinion teeth hit the back of the chassis and if I got the shaft machined down so it would fit properly then it will eat into where the grub screw goes.
Anyone know any mods to make these ones fit that doesn't involve touching the chassis or machining the pinions?
#9628
Smaller spur.
#9629
Originally posted by AzNDRAGster
Smaller spur.
Smaller spur.
The pinions cost me NZ $27 each as it is.
#9630
A spur is inexpensive and its an easy fix without modifiying anything. Just your gearing, but you already have the correct range of pinions.
