Team Corally RDX Phi
#1126
#1127
I've been having a lot more fun with rubber, I can see why it's so popular. I also feel like I'm learning to take better lines, drive with more control, and have a better sense for what changes to setup do to the car. But that whole foam/rubber discussion is well-documented elsewhere, and not one I want to venture into.
Thanks for putting my mind at ease about the EU kits, and the parts included. I'll give Jeff a call if I decide to go that route.
I've heard Josh's car is the "best rubber car ever seen" a few times now in different threads. It seems like that guy has the midas touch when it comes to rubber tires.
#1129
What about front and rear toe, downstops and caster? Thanks Josh. I will try it this week.
#1130
roll center low in front and high in rear
front shocks.....35wt assoc oil w/tam 3 hole pistons.....middle on tower and out on arm....19lb spring
rear shocks.......25 wt assoc oil w/tam 3 hole pistons.....1 hole in on tower and middle on arm.....17lb spring
wheelbase middle in front and short in rear
camber link up and middle front and rear.....middle on rear hub
width in front .4mm shims.....no shims in rear
oneway......no swaybars
rp30's and a mazda6 or speed 6 lightweight body
sauce full rear and full front.....jtg
if I forgot anything...just ask
Snowy.
#1131
I knew I would forget stuff
castor...3*
camber.....1.75*
rear toe....stock, no shims.....2*
front toe.....0
droop.....3mm above ride height....subject to change with traction
castor...3*
camber.....1.75*
front toe.....0
#1132
One of the nicest cars and electronics layout I've seen with brushless.
I am also very much into building clean cars with layouts such as yours.
You may check out my blog and you will see what I mean..
http://jdracing.blogs.se/
#1135
#1136
#1137
6 cars in the stock A right now in cleveland..........not to shabby
