Team Corally RDX Phi
#2851
Sal,
Thanks for the input. I'm trying to judge where to setup car up while i rebuild it, and the only setups I have are years old.
DC,
Ya man, good to hear from you. I'm trying to gather in what people are running and figure out where to initially set my car up. Mo and X-man are in the plans for setup ideas too.
DC,
#2853
#2855
#2857
Are you changing front end more or rear end? I would think stiffen up front oil and maybe raise the rear roll center.
#2859
haha Just usually the first things I change when I am slowing the car down. Hopefully ill be down at 360 for the Grand slam race.
#2860
SWAP
Hi guys,
Iv got a CEFX Cyrul chassis and shock towers plus a corally 2.9mm carpet chassis and low towers that i have no use for hear in Aus. so im willing to swap the 2 chassis and 4 towers for 2 standard towers and 1 2.4mm chassis.
My items are brand new and have only been installed on a car, NEVER RAN! So i'd be wanting a new chassis and towers.
Anyone whos interested please contact me!
Cheers,
Rhys.
Cheers,
Rhys.
#2861
#2862
Hi has anyone tryed the new rear hubs, they look like the Tamyia/Cyclone
style with the ball studs stight up... they look stronger then the old 1's
would love any info on these.
#2863
#2864
For anyone looking for these uprights part number is COR79299 same as old 2 hinge pin hole upright. I found if you use 2 corally steel shims/washers in inner hole you'll be right where the 2nd hole of old upright is. Also I would suggest ordering camber link COR79262 to make rear link straight off tower. These are a great upgrade and they are way stronger.
#2865
hey guys i am running the phi diffs and they keep coming loose on me. i saw back in the thread that you put the cone washer in and that will fix it but it didn't fix it any idea's that would be great thanks
