Team Corally RDX Phi
#1353
To fit heavier BL motors and lighter lipo batteries, I hope that Corally (or Specialized) comes up with a wider chassis (on the right side) that will allow us to move the lipos outward to balance things without adding a ton of weight to the battery side.
#1355
Thoroughly understood. But, I would rather keep the car light and only place weight where I want it to be.
Another option would be for Specialized to develop a new offset motor mount for the Phi. That would go a long way towards helping to balance the chassis with BL. I may look into milling down my existing Rear Bulkhead/Motormount to bring my BL motor inboard.
#1356
Super Moderator
#1357
Does anyone still blueprint the shocks? I know you don't need to cut down the shafts on the phi, but does anyone still replace one of the o-ring with a washer?
http://www.corallyusa.com/2005/shocks.htm
#1358
Sorry Joel...Other than not twisting the plastic cap when screwing it onto the shock body, I already knew about the other blueprint suggestions. Never replaced the second o-ring with a washer.
Does anyone know what part number COR10013 is? Described as "Thrust Washers US Spec Universal Wheels (1 pair)."
I can believe that they are just "Thrust Washers"; but, the reference to "US Spec Universal Wheels (1 pair)" does not compute.
Thanks.
Thanks.
#1360
Thanks.
Thanks.
The thrust bearing in the Phi is also the same thrust bearing in the diff on the sp12x us edition for "us type" wheels.
-Korey
#1362
#1363
Any other team driver build tips for the phi? Thanks.
#1364
what is the advantage of the low shock towers????
#1365
Jacko- Yup... get losi part number A5050 and take the biggest spacers in that bag and replace the inside spacer and 2nd o ring in the shock with that big spacer. That link just posted shows how to do it
Joel- None that I can think of really. The car is pretty good out of the box with the setups we supply online. I put a little CA on the threads of the diff and wipe off the excess to help "enlarge" the threads slightly. That seems to help them from loosening up. And... when running the very outside hole on the rear arm for shock position, I just use a ball stud and ball cup for the shock end.
Eddie10- Low shock towers were general designed for racing on carpet with foam tires. It allows us to lower the body more to give better aero performance.
-Korey
-Korey
