Team Corally RDX Phi
#1891
#1892
I have a question about the shock trick using the losi spacer. When you perform this, does the shock leak out of the bottom? I did it to one of my shocks, and it makes the shock shaft seem real loose, so I was worried about how well it sealed. Also, do you guy use this set up on asphalt, or just foam carpet racing? Thanks
Jeff
#1893
I currently have the single o-ring setup on my rubber carpet car. Cannot call this a recommendation.
#1894
The specialized RC lower kydex bumper mounts on top of the oringinal lower bumper piece right?
#1895
#1896
#1897
I was curious if anyone had a idea when the left and right rear bulkheads were coming back in stock?
#1898
#1899
I've had one of those for a while now. I'm a machinest ... I tend to have more problems with the right rear bulkheads though... Clancing the sweeper and sending me straight into the outside wall at the hobbyplex.. Sad part is I did it there a month before nats, and while at nats :-/
#1902
Well, I actually JUST noticed these. They only have room for one oring... which is cool. The main idea I think is to get the shock pistons further down in the shock so it doesnt bottom out on the bladder.... or so the shock bottom doesn't hit the bottom of the shock body.
But... I haven't seen one quite yet so I wouldnt be able to give you an EXACT answer
-Korey
-Korey
#1903
-Korey
-Korey
