Team Losi JRXS Type-R
#9706
The one big advantage of the Type R over any of the other chassis's out there is you will never have to tape a battery in your chassis. That alone is a big reason to get one. I don't know how many battery ejections I have seen already this season with improper taping or just tape wearing through during the race. I know I will never have to worry about that. In fact if you ever see a battery eject from a Type R there has been some sort of catastrophic failure!
#9707
#9708
Any of u's using this product yet? Ordered one today, so going check it out. Did a search on here but got nothing.
From flying fox. Was on red r/c awhile back.
The Flying Fox JRXS Type - R Layshaft combines the Layshaft, right Pulley Mount and standard Spur Adapter into one piece of precision machined 7075 Aluminium.
The benefits of this design are:
Choice of different spur gears and wider range of gear ratios
Slightly lower rotating mass
Absolute concentricity of spur gear and pulley
Wider pulley spacing allowing better choice of Lipo Batteries
Zero backlash between right and left pulleys due to the clamping effect of a screw rather than an e-clip to secure the left pulley
#9709
Received the new FlyingFoxRC Layshaft from SkyRocketBatteries today and installed them in the car. The quality is very good and the installation was smooth. NO DREMELING required! CHEEERS for a product you don't have to dremel to get it to fit!
I was concerned that there maybe some added drag in the car with the pullies widened but there doesn't seem to be on the bench. The fact the layshaft removes the e-clips from the design is worth the cost alone.
#9711
#9712
#9713
I ordered mine this morning from them directly. Said nothing about being out of stock and payment went trough.
http://www.flyingfoxrc.com/
#9714
I've gotten to run the car several times since installing the product. My laptimes have suffered no negative impacts, the spur and pullies are running very true, the removal of the drive train backlash makes the car very consistent coming off the turns. The cost of PRS spur gear adapter and Losi JRXS "downgraded" layshaft almost equals the FlyingFoxRC layshaft and the quality is not near as good and you will save time in modifying the pullies to fit some of the lipos and be a lighter overall setup.
#9715
Company Representative
I'll add to my review.
I did downgraded my shaft to thicker one
bought a RPS adaptor
and of cos spend hours to shaved those pullies down.
#9717
The next shipment of layshafts will arrive in the States in just over 1 day. If you order from me it takes around 10 days postage, so it will be quicker and a little cheaper if you can wait to order from SkyRocket. http://www.skyrocketbatteries.com
A big thankyou to everyone who has bought one. I hope you are as happy with it as I am.
Cheers.
#9718
if your going to buy the type-r then I strongly suggesting you to buy that shaft, before down graded a shaft (to prevent spur gear grindiing), buy RPS adaptor (to fits a smaller spur gear if you race 13.5 or 17.5 BL moto) and shaved pullies (to fits most Lipo pack)
hope this help you
PS: I hope this dont stop you from getting the type-R, its a Great car
hope this help you
#9720
As for the layshaft... I was lucky enuf to run a prototype for a while before the went to production. There are no negative sides to using it but the positives is quite a list. In short it makes the chassis more "normal" so you can run normal spurs and have zero lipo problems. There is no good reason not to use one
