Team Losi JRXS Type-R
#7096
Look, when I do this. This right here. It just gives yall three sets of nice boobs to look at over there. Photo series starts tomorrow night. Be there!
#7099
Do you have any evidence to back up that claim? To my recollection, Xray have released one option part for the 008 since it was released in December (the front brace). That option part was mentioned in the manual that shipped with the first batch of kits, so it's not a late revision released as a reaction to performance. It is a tuning part developed during pre-release R&D that finally made it to production (low priority, it seems).
#7100
loose back end
Hello fello racers, I am looking for help...
I must say I love my type r and one thing that I have made changes to is using o-rings to remove the horizontal play of the a-arms, both front and rear. This addition has made the car more precise. I have combined this with motor shims as mentioned in earlier posts. Using only motor shims and the included kit shims, made the a-arm to tight and discovered that o-rings help remove play, and alow movement in the event of a crash. Not sure if this is enough movement as I haven't crashed hard yet, but I will help. The best part is that the a-arms move freely when the shocks are disconnected to measure downstops..
Anyways, I would like advice on how to remove the lose feeling of the rear. To explain the characteristic, when exiting a corner on power the rear will drift outward.
I have tried softer springs (12.5) rubber tire (jaco yellow) and has helped, but not entirely. The ESC (novak xbr) is positioned on the passenger side of the car with the the receiver on the other side with additional weight to balance left to right. Typical setup of most car pictures..
Would one position the esc and weight further back on the chassis to help with weight transfer or try something else?
Your thoughts and help is appreciated.
Gordon
Gordon
#7103
I'm glad you asked that question. The rear of my car wont stay planted either. I know one thing I know was doing wrong was too much rear toe. Every setup sheet I saw listed 3 degree so thats what I had. Then I read the more the rear tires point inwards, the more wishy-washy the rear will be. It also said for stock racing run less toe anyways for max speed. I'm trying standing the rear shocks upright as well. But I would like to hear from someone who knows, because I dont, the best way to correct this?
And about the option parts, are you serious Xray has only released one for the 008? Seems like more. But do you understand what I'm saying as far as selling the same car for over two years with no new parts other than the lipo tray? I know some will say thats a tribute as to how well designed it was, maybe. But it almost took an act of congress for them put out the lipo tray again, so I'm not holding my breath for anything else.
#7104
Gordon
Gordon
Try going up to a 15 lb rear spring and use stock shock piston along with 30wt shock oil to start. Sometimes a softer rear spring will make a car feel loose. Also run rear diff in low setting and front in high setting. Sometimes too a softer tire will feel loose as they get too hot fast and get greasy. I have never liked soft tires. Try diffrent tires also something aroung 30 compound. Jaco greens,Sorex 36 tires seem hard but are really great tires..
#7105
Trader Rating: 7 (89%+)
wow wow and wow....
I got my oneway and wanted to install it. look easy to do it but wait a minute, I think that I have to uninstall my previous dogbone and put the shorter dogbone that came with the oneway.....
so i stopped and put back my diff.
so switching from diff to oneway is quit a bit difficult. no like the xray car.
any advise?
any advise?
#7106
Build a complete set of LCD's with the shorter bones.
#7107
wow wow and wow....
any advise?
any advise?
#7108
this is what I will do.
thanks
thanks
#7109
someone have a good setup for carpet/rubber/13.5BL
or is there a place where people are posting their setup?
i went to the losi web site and only 2 setup there.
thanks again for your help
#7110
I am unsure if this will help anyone but when i treated my self to a brushless setup this week i found it extremly hard to work out where to put everything after lets of messing about and testing diffrent layouts i think i have found one that works
can anyone pick any faults in this layout as i dont want my speedo to get damaged on any impact .. thanks
PS. i woudl liek to thank jal874 for his help via PM regarding how best to layout the speed passion brushless
First off i needed to change the way the battery bars were positioned on my batterys these angles fit very well the - is just behind the sput and the + just behind the reciver
Top view
side view
hopefully this will help some people out with how best to layout there brushless ?
*Edit*
maximebeauvais there are some great setups on this site hope it helps
http://team-spoon.bravehost.com/#tl
Top view
side view
*Edit*
