Team Losi JRXS Type-R
#5446
how are you guys wiring your fan to cool the motor. I am running BL with a GTB. Are connecting the fan wires to the SC or to the battery itself? Any pics?
#5449
Dos anyone experience problem when using 3.5 or 4.5 brushless motor? I'm using 128 spur with 24T pinion. This is the smallest pinion I can use. Otherwise, the pinion can't touch the supr. The final gear ratio for 128/24 is and this is 9.76 too low for running low turn brushless motor. I want to get like 10.5 final ratio. otherwise, my motor is way too hot. What is my solution? Do you think this is Losi bug on the gearing?
#5450
Super Moderator
#5451
#5455
*deep breath*
I'm frustrated because I just wasted half my day driving to and from the track, but...
What's up with the one way? One of my bearings had two rollers fall out as soon as it was removed from the package. It worked okay without them, though that side didn't spin quite as long. Today, during practice, the other side blew up and was completely unusable, thereby ending my day.
So, what's the deal? Is there some kind of ritual for these things that I'm unaware of? Do I need to sacrifice a virgin diff to the R/C gods each week to make sure my one way doesn't shit itself? The only thing that's wrong is the bearings are bad, but it looks like I might need to buy a whole new one way in order to fix that. :-(
#5456
*deep breath*
#5457
This does not surprise me since the first gen one had bearing issues as well. All the new one is is the old one with the bearings swapped. It is possible they have a bad batch again. Hit Todd up and he may be able to help you with it. I don't believe you can really replace bearings in it since they are pressed into the tube.
#5458
Im not sure, whats wrong with yours. They are a kinda rough to build, but once put together right I havent seen one mess up. We have a couple and all are out of the package and work excellent. Maybe schreff can come on and diagnose your problem, hes good at putting them together.
#5459
hey can larry or jason post up an carpet set up for the car
#5460
As Larry said, I've put about 3 one-ways together now.
I've only had 1 of the 3 have issues with one of the bearings. One of the needles fell out and it's gone. The one-way is in a car right now and it seems to work just fine. That's not to say an issue won't occur though. It's in Tags car and we ran it like 10 packs over this past weekend with no issues.
As far as a carpet setup, the one I have been having good luck with is posted on one of my posts on this thread. If you're talking rubber tire carpet, I'll grab Tags car before I ship it back to him and try to work on a setup sheet. Keep in mind, the tires we ran on Tags car were the first gen Jaco Greens. The rubber is very thin. The tires that they will have at Vegas are going to be thicker so I'm not sure how much different the car is going to handle.
