Team Orion 3200mAh Race Spec LiPo
#1487
gymbeam , its to late there here , ray
#1488
you can't use discharge curves from a low 20 amp discharge rate to compare lipos to nimh. Lipos do not respond to constant current in a favorable way.
#1489
I didn't see any insults He merely stated the fact that the good NiMh packs are faster in stock and 19t... and in a big race you go for all the speed you can find I don't know how relevant that info is since LiPo isn't legal at a "serious" race yet but his facts are right.
Personally I love my 2 lipo packs for practice I beat the crap out of them and it saves my good packs for racing I just hate the fact that I have to bolt in all that weight to get my car to balance out
#1490
How many NiMH packs will you burn through keeping that voltage edge while the lowly LiPo consistently delivers its same voltage for hundreds of cycles, without fail? Yes, NiMH has more voltage in certain situations, and is probably faster in that sense. If that one thing is all that matters, stick with NiMH until they dry up.
LiPo will allow you get get your car to exactly the legal weight limit. Depending on your situation, especially with heavy brushless electronics, this may benefit you more than a little extra voltage if your car is heavy. You also have the option of shedding a few ounces if your club rules are flexible, and making up for any disadvantage you may perceive because of voltage.
#1491
#1492
Mainly because it doesn't reflect how that battery will operate in a real world environment. We don't race our cars at a low constant current, why do we expect our batteries to perform perfectly at unrealistic conditions? You are taking a test that gives dependable information from one type of battery and applying it to something new and expecting accurate results. And you can continue to insist otherwise as it seems your mind is made up anyway. The people who are using these batteries will continue to be happy without your approval of them.
And please, the lipo manufacturers are not saying you can't use them and have admitted they don't look as good at a 20A discharge. This has been discussed many times in many threads here. It's not some big conspiracy to convince people to overlook that info.
This is another graph from the TrackPower PDF... As was said before you would need to test against more than one pack of each to be representative. we don't really know the condition of the packs used.
#1493
What I think what would be a more beneficial test is something that will simulate the loads that are placed on a battery in racing conditions - variable. Anything available that is capable of that yet?
#1494
I received a note recently that TrakPower/Thunderpower is using two different cells, both from Enerland and Saehan-Enertech. I guess the Enerland cells have shown issues with cycle life, while Saehan-Enertech may be superior to even Kokam. It sure would be nice to know what cells you're getting. I'd happily pay a few extra bucks to try specific cells.
#1495
If I am racing with the fast guys and they are all running NiMh I am at a big disadvantage running my Orion 3200, power wise... sure they will last MUCH longer than my NiMh but I am a racer... I RACE... if I have the choice and its legal, I am running the faster car/motor/tire and battery I have. If I didn't care about winning or I was bashing I wouldn't own a NiMh.
As I stated... I own two 3200 LiPo Packs.... I like them I use them often but from a lot of track time with them I can say they are NOT as fast as my good NiMh!
As for balance unless you run a Losi lipo sucks... with the B/L in my car I need a extra 40 grams on the battery side with a NiMh and around 250 with a LiPo. I cant get anywhere close to the legal min weight with a B/L and ANY type cell so I cant see how LiPo will help me get to legal weight or "shedding a few onces as you state it will
Lighten up guys.... most agree that LiPo is superior in most ways (me included) but I am not closed minded... I can see they are not better in SOME racing applications... stock/13.5 at legal weight. That was all I was saying.
#1496
ottoman - You are absolutely right about the stock class and likely 19T. Lipo will not have a beneficial impact in that area. I think it will take off in modified as the voltage edge of NiMH has less of an impact. Then once it has proven itself to not be as dangerous as assumed maybe then the concept of an easier to maintain and lower cost battery solution will outweigh the loss in voltage for the stock racer - who knows?
I have no intention of messing around in stock or 19T again so I guess the answer is easy for me.
