Official Titanium Racing (TiR) Thread!!!!
Hi all,
Welcome to the official Titanium Racing thread.
If any of you have questions or advice on our products, either PM me or post a thread on here and I will will do my best to help you out.
Regards
Paul Webster
Titanium Racing Ltd
Regards
Paul Webster
Titanium Racing Ltd
Team Almighty in the uk stock a good range of TIR products check out there full range.
www.teamalmighty.co.uk
Who sells TIR in Germany?
Hi D_o_S,
I shall find out tomorrow if we have a distributor in Germany. You will then be able to order our products through your LHS. If we don't, I suggest ordering through our website at:
www.titaniumracing.com
Regards
Paul Webster
Titanium Racing Ltd
Regards
Paul Webster
Titanium Racing Ltd
Quality
I have numerous parts from TiR,
Input shafts for a Yokomo SD are never true nor does the screw depth for the drive grear be deep enough.
Had 4 drive shafts all break cos of air bubbles in the mould and had 2 axles shear.
No this is not from hitting anything hard or having the steering throw to great.
As for pinions I wont even go their
Originally Posted by dr_hfuhuhurr
On a somewhat related note, buying TiR parts will not improve your spelling or punctuation.
outdrives
I have a TiR spool fitted in my BD twice yesterday the outdrives come out sending the car into spin and destroyng my race.
are TiR going to do anything about this problem? i understand this is a common problem.
Hi all,
yoko - when you replaced the outdrive back into the spool unit did you hear it snap into place?
Bob - What is your issue?
Regards
Paul
Regards
Paul
Ive had a few TiR products, including a Pro4 spool which was excellent.
Currently the only TiR thing i can find is my worlds pinion set. There amazingly light and no complaints there either.
Shame some other people have had bad experiences.
Hope that helps
Hi Bob,
Unfortuantely,some times the pinion holes do come slightly smaller. This is due to the anodising. Sometimes the pinions are left in the solution a bit too long and the anodised surface builds up too much and the hole becomes too small. Usually drilling the hole with a drill bit will cure the problem.
Regards
Paul Webster
Titanium Racing Ltd
Regards
Paul Webster
Titanium Racing Ltd
