MTC3
#421
This is what I was worried about hearing, I would guess it's only around .8mm thick around the motor cutouts, incredibly thin for aluminum to retain trueness. Ironically Xray sells a 1.5mm thick Flex Alu chassis that they state in the description that it's strictly for competition races only and has reduced durability. This bleeding edge advancement in chassis design has its limits for independent drivers like myself that can't pocket $130 USD chassis over a small oopsie, I'd have preferred they offered a MTC2 carbon chassis option. Not sure if I want to "upgrade" to the MTC3 just yet. Maybe see if Mugen does something down the lines like the steel chassis or a MTC3R with a carbon chassis option.
#422
#423
R/C Tech Elite Member
Youll split the laminations on a 2mm CF chassis easier then you will bend an alloy or steel chassis.
You may not crack it visibly but at that point your CF chassis will be a wall trophy.
And thats if you dont rip the 90* screw heads through it first.
#430
Another friend with the MTC3 was crashed into on the straight when another racer jumped the track and nailed him on the left front. The front left was completely mangled and the chassis seems to be bent as well.
#431
I am guessing you're machining chassis out of quasi isotropic CF plate such as dragon plate? I have wanted to try this idea for some time.
https://dragonplate.com/quasi-isotro...n-fiber-sheets
#433
#434
When steel bends, it doesn't "spring" back (unless its spring steel). And if they are using steel as a means to make 1.0mm to 1.2mm thick chassis's to get weight down ultra low center of gravity but not weigh too much, all of these ultra thin chassis's will fold like a wet noodle ...LOL
If they offer a thicker 2.0mm aluminum chassis, I'd probably run that and just adjust where I can to make up for the increased height. Unless you're Jacob Cruz, Ron Volker, etc most of us club racers probably won't realize the benefit before we hit something and tweak it. A tweaked thin chassis would hurt our lap times more than just running a thicker chassis that's more durable. I should have all my kits, parts and option parts later this week so will be building one of them for myself to race later this month on a decent sized outdoor asphalt track. So we shall see how the chassis holds up to my driving. Jackson Raceway here in Jackson, NJ has concrete curbs but they're smooth if you ride them right
#435
780Likes
