Tamiya MB-01
#98
I'm sure I said the same thing when it was released. This is just a cheap way for Tamiya to put a nice body on the shelves, and let it move under it's own power.
I have no expectations that this will be a performer, I doubt it would even be a match for an M-03/5/6 (I have no experience of the 01/2/4). Weight and motor placement is all wrong.
But this is what Tamiya seem to be focused on these days. Dirt cheap basic chassis that are one step beyond a body mount. Weird mid-range chassis that are worse than anything they made in the 00s. And top-end chassis that are several years out of date on the rare occasions they bother to release one.
I'm sure there is a market for them somewhere in the world but it isn't here in the UK. All that Tamiya sell in decent quantities are the re-releases of the 80s off-roaders. And that bubble may have burst based on the big discounts available.
Their RC lineup is a shadow of what it was.
#99
Look, if it's easier to work on than the M05, even if it doesn't perform as well, it's a win in my book. AT MINIMUM, the symmetrical suspension is a benefit. Especially for the new driver crowd.
.. I'd love to do some head to head stuff with the MB01 versus the M05 and M06.
#100
#101
Also the parts compatibility with the TT series is good. I mean, hitting the market, and we have gear diff, ball diff, spool, and oil filled diff already in shops. It uses normal mini length shocks. And.. has droop screws! If I didn't have a M08, I'd still be looking for a good solution for my M06.
"being able to work on it without 30 screws of heck" is still a big thing here. If I never have to do the 10 screw trip to the M05 diff again it'll be to soon.
#102
This is the video of the stock kit running in RWD on a track. it’s not bad considering it’s running the pogo sticks shocks, stock tyres and heavy abs faux engine in body.
https://youtu.be/HuyF92Iq1W4?si=R97Db0IYAx9ONInh
#103
I am super excited this kit is on the market. If nothing else maybe it will help produce more bodies for the M07/08's.
#104
Part way through my build now. So far not impressed with the build quality, it's definitely a downgrade from the M05. First issue I've run into is the P7 suspension balls pop out of the arms way too easily, they popped out several times while trying to screw in the king pins. Second issue is the o ring in the drive shafts cause the suspension to bind badly so I had to leave them out.
The arm plastic seems very different to the rest of the kit. They feel rubbery, trying to snap them off the parts sprue just lead to bending and stretching of the flashing. That's probably to make them flex instead of break in a crash.
#105
