GT12-RT
#826
Glad to see a rule set. Minimum weight is kind of disappointing. That low means guys spending money on light weight parts. In running this class and teching at a 750 min weight, I saw very little ballast being added to get the car there. Seek out those light weight batteries folks.
#828
R/C Tech Elite Member
#829
On two scales, I checked the weight of my aluminum chassis X12 '22 and it was 713 grams with SJT tires, USGT motor, Hobbywing XR10 Stock Spec 1s ESC, Gens Redline 1s battery, futaba receiver and servo. It even has 5 grams of balance weight and a transponder. Now the body that I got (SuperRad SR-04) is 44 grams which is AWESOME that its illegal by 1 gram.
#832
#833
#836
#837
I read "chassis" as everything minus the body. All throughout the rule book they have distinguishing language between body and chassis. Is that not correct?
For the body, you are correct, I will throw another coat of paint somewhere to help the weight. I thought of that just after I typed my previous comment.
#838
Looks like the superrad (as I have it mounted) is ~67mm from the bottom of the chassis.
#839
So here is my take on the three diff types. My setup and my opinion. Spool can be fast on a very smooth and high bite track but you can throw it all away in a single corner. Ball diff is easier to drive than the spool but just a touch off the fastest lap you can run with a spool. Gear diff is the easiest to drive and will typically produce the faster overall run mainly because of that. The car can be driven aggressively with the gear diff and not get you into bad situations. Consistency can be the name of the game.
#840
