GT12-RT
#796
From Saturday Motiv race. I’m consistent. But about it. Tan 2 different versions of the USGT motor. We had 28 for GT12. My fast lap was the 6th place average lap. D-main https://youtu.be/1sa7tCtK6io C-main. Mine https://youtu.be/iwW8uCFfYCM B-main https://youtu.be/px-MTf39Yzc A-main. https://youtu.be/L7WMIY01s8c
#797
Unfortunately, I’ve developed a lot of bad habits with off road. I can get away running an imperfect buggy. And still run relatively competitively. It doesn’t work with on road.
Correct. I can’t fix my handling problem. And I’m basically stuck in the middle. 4 laps up on the backfield. 4 laps down from the front.
Running GT12 and stock 1/12 have definitely improved my off road driving.
#798
Brought all my parts to track to finish assembly. Took about 2 hts. It was a bunch of used and new parts laying there. I finished assembly about 45 seconds before my first qualifier. The car was great. By the main I was only 1 second off fastest gt12. I ordered smaller servo saver. Will clean it up and dial in before next race day. Had a blast. Thanks for the help.
#800
Brought all my parts to track to finish assembly. Took about 2 hts. It was a bunch of used and new parts laying there. I finished assembly about 45 seconds before my first qualifier. The car was great. By the main I was only 1 second off fastest gt12. I ordered smaller servo saver. Will clean it up and dial in before next race day. Had a blast. Thanks for the help. I am not instlling smaller wires. 16 gauge is barely bigger than the double windings. I feel like i would be adding a couple winds on the stator.
#801
I am going to need a new diff of some sort as the xray ball diff is pretty much at it's limit with a 68. My options seem to be to get a new ball diff, (I am hearing good things about the roche), the Awesomatix Gear diff or to learn how to drive a spool. I want an awesomatix gear diff, but they seem to be out everywhere in the states.
#802
Thanks. i will fine tune other wiring. I was just excited to get feet wet with it. Was worth the thrash to get on track. 6 inches. I had the only kinda looking scale car. All others were almost like normal 1/12 body's. My porsche body definitely looked coolest.
#804
Really that is 6in? I need to play with .mine then it is the same length and I feel it looks odd
#808
#809
Anybody purchased the unmounted SJT’s and mounted them themselves? Would love a set of rubber tires on the Yokomo yellow wheels.
