3racing Cero Ultra V1 & V2
#842
does anyone know if the sport lower arms can be installed on a cero ultra v2 (short wheelbase) carbon chassis plate?
#844
Is there an upgrade path from the v1 Ultra to the v2 Ultra, or would it even be worth it? What exactly has changed between the two?
#846
3racings website has the aluminum shock and sway bar mounts back in stock for the ultra v2
#847
#848
#849
studs were also a weak point. Thanks for your info…it’s appreciated.
#850
Our track is close cntact racing and the outer wall is solid (indoor, black carpet). It is easy to break things.
#851
If you upgrade to alu, you're just going to transfer the damage to something else. It might be the ball stud, the screws holding the little mounts on, it might just pop off the arm. I took the approach to just get a bunch of plastic ones and see how it goes. If it starts being a race ender issue, then I'll probably be getting the alu mounts myself, but in terms of easiest thing to fix, those little plastic mounts are easier to replace than shock shafts or the ball stud sheering off and having to replace both the ball stud and alu mount. Just a thought.
#852
#854
Just picked up a V1 Cero Ultra and looking to convert it to an ACE - do I just need the ACE aluminum chassis, one-piece upper deck, and 2x 351 belts? Also wondering what spares are recommended to keep on hand?
#855
What ver?
If I was yo buy new cero what version would be best for me? I run on 7-8 short older black carpet med grip 21.5 tc. Ace or v2 . What springs would you use?
