3racing Cero Ultra V1 & V2
#547
What sticks out to me is that your belt is resting on the left side of the pulleys and the previous set of pictures had the belt resting on the right side of the pulleys. That's probably a good 1-2mm worth of clearance. Manufacturing tolerances will tend to dictate which side of the pulley the belt naturally gravitates to.
#548
You’re correct in the belt placement between the photos…I didn’t even notice. Here’s one with the belt pressed to the right.
#549
Aluminum spool: 5.1mm
Plastic spool: 3.4mm
Cero gear diff: 5.6mm (pulley is centered)
#552
Have you tried flipping the pulley?
#553
Super Moderator
Here is my setup from Sunday’s club race track temps were 158 degrees after each run the tires were coming out between 163-171. The car had really good traction all day . KrazedBuilds is currently working on a carbon version that I should be able to be testing pretty soon
#554
