Team Associated TC5
#8551
hey everyone.
i need some advice on an idea. i broke my last dog bone blade 2day and prob wont have any for my race this sunday. so i cant use my spool. wat bout if i take the diff with the plastic outdrives, remove the balls and put some superglue in there and tighten it up. hey presto! a spool think this will work? im thinking the plastic outdrives might break or bend but i only race 540 class so should be ok
thanks treemagnet
thanks treemagnet
#8553
I've been looking at the ppdbillet weight and specialized RC battery tray, and prior to pulling the trigger I had one question. It looks like the battery tray is offset to the outside a bit. The ppdbillet weight has inserts that fit into the battery slots in the chassis, locking it in place. So how do these two work together if the tray is offset off the side of the chassis plate?
I saw a post taht said they fit together beautifully, but just cant visualize how that works.
#8554
The battery tray also has two mounting options, so it doesn't have to be mounted so far out on the chassis.
Hope that helps.
#8555
I'll try and get a picture.
#8556
I would think that the Specialized would mount similar but haven't tried it myself. I'd be interested in a pic as well. Tray sits on top of our weight plate on the DD version, screw in and lock both in place.
#8557
#8558
got them both in today and installed in the car. they work great!! specialized rc plate is machined underneath to clear the weight plate.
#8559
For the frugal folks....I modified the stock battery 'guides' or holders that come w/ the kit for 6cell packs to help hold the battery in and keep it off the belts. I simply sanded them down so the pack sits flush against the 'guides'. hard to explain but I sanded one guide on the pack side and the other on the side were the screws go in. depending on which one I use it pushes the pack to the outside similar to the corrary tray to help offset the heavy motor side. I'll try to get some pics.
#8561
hey everyone.
thanks treemagnet
thanks treemagnet
#8562
hey everyone.
thanks treemagnet
thanks treemagnet
#8564
Hey. Thanks for all the feedback about the ppdbillet weight and SRC tray. Think I'm going to have to go for it!
Anyone got a decent rubber tire, asphalt, 17.5 setup?
#8565
here's a bad picture of my specialized tray and PPD plate. I don't have it mounted all the way out. The other set of mounting holes push it out another 1/8" or so. Far as I can tell it mounts the same way as the Diggity tray. I think you have to click on the picture to enlarge. Never posted a pic in this forum before.
