Team Associated TC5
#7906
Sorry.....that should read...>>bottom steel<< plate...my bad. Used this at The Halloween Classic for the first time ,works perfect!!
8up-racing 108% 8up
8up-racing 108% 8up
#7907
Trailranger, where did you get the helicoils small enough for the 4/40 thread? I can't find them at any autoshop or home depot style place I go to.
#7908
Tonight I put Josh's latest setup on the car to try out this weekend.
Also, does any one else have any experience with Jaco blue and green tires on a low bite track? I have been running green, but should I consider running the blues?
#7909
The Blues were specifically designed to run on carpet and are the spec tire at almost every big US carpet race. The blues are fantastic tires that wear really well. I have tried greens at my local track and did not like them, but I did not change much on my car to make them work. For low bite I would guess that greens would be best, but honestly I would try to make the blues work.
#7911
hey can somebody explain the affects of lowering or raising the roll center? i need less traction.
i am going through a traction roll problem-besides changing brands of tires -- i want to change the roll center.
there seems to be conflicting information going around about this subject.
#7912
#7914
I agree with ottoman.
Also i ran jaco blue tires on an almost brand new carpet with low bite. They worked really well, but i do run my car very soft. Its easy to drive and pretty quick.
I am awaiting the next time i can get to the track cause Josh H's setup should be very very good. He races at my local track from time to time and he did turn fast lap with that setup against some very good drivers.
#7915
Lower Roll center give the CG more leverage to ROLL the car.
Higher Roll center less leverage, less roll
#7916
Traction Roll
This is my understanding, all the pros please correct if wrong.
#7917
hey guys, should the belts be very tight??
Mike
Mike
#7919
