Mugen MTC2
#827
#829
I apologize if this has been covered earlier on this thread. I am having issues with finding a "ticking" in the drivetrain when cornering. If the car is on the stand, I can go WOT and turn the car from lock-to-lock and it doesn't make the sound. This leads me to wonder if it is the belts touching at the spur gear when under cornering load. Ideas? Opinions?
Thanks.
Thanks.
#830
Thanks.
Thanks.
#831
Check to make sure nothing is touching the outdrives on all four corners of your car (lf,rf,rr,lr) Check the red area in the picture below. Sometimes the screws can be screwed in too long and touch the outdrives under load. As mentioned, the black clips on the front outdrives can be the first thing to touch the outdrives in this area.
#837
The bypass shock cases do not behave like the sleeve inserts found in the X-ray. They do exactly what they are named, they allow the shock fluid to flow passed the edge of the piston and not through the piston orifices. Greatly reduces the shock pack. I believe they work more effectively if a piston with three holes were used. If you plan on using them with the stock piston, I’d almost double the shock fluid viscosity. The Officina variant of the bypass is a bit more progressive but not much.
#840
