Mugen MTC2
#976
Not sure what surface you're racing on but we have high grip epoxy over concrete on an indoor track (very close to black carpet if not as good) and I use the rear T brace on a carbon chassis and it seemed to help.
#977
You can get away from the front blades altogether. I installed the Arrowmax 53mm ball bearing front drive axles: AM Arrowmax XRAY T4 53mm Ball-Bearing DJC Driveshaft Set (2) [AMX-010061] - RC Planet It's a pricy upgrade but I won't be going back to blades....EVER. To me this is a MUST DO mod.
#978
Everything you need comes in the bag if you buy the 53mm kit. The first one I tried was the 52mm and they were too short, had to shim the inside of the outdrive 1mm to get enough bite that the axle didn't pop out of the outdrive. No such problems with the 53mm axles. Some have told me the Xray X4 axles will work too, have no first hand experience with the Xray.
#979
"high grip epoxy over concrete on an indoor track" This caught my attention - would love to hear more about this racing surface!
#981
Contact P&F directly to get product specifics.
#983
#985
I found the Xray blades fits in case you need one.
#986
#988
If you're looking for a nice lightweight (or std) 3-D printed bumper for your 1/12 Pan or 1/10 TC FabTek Engineering has some really nice ones and makes one for the MTC2. Owner/engineer is pretty fast racer whose home track is 180 Speedway in MD so it's tested as well.
https://www.fabtek-engineering.com/
#990
