Will Tamiya Adjustable suspension blocks fit a TB03?
Just picked up a good spec TB03 for a bit of club racing, but it still has the kit plastic blocks. I was thinking for the inboard rear i could use the new adjustable blocks so i can tune the toe in, but on the TB03 the inboard block position is not compatible with split blocks and the solid blocks run upside down with spacers to bridge over the stiffeners in the tub. Does anyome know if the adjustable blocks will fit? They are quite a different shape to the regular 1XA block that would be the fixed option.
Check out the following website.
https://www.thercracer.com/2017/01/t...-ultimate.html
This website is arguably the best online resource for understanding how to use all the different Tamiya adjustable suspension blocks including the newest versions of blocks. Note only does the website have the different Tamiya part numbers, but it also has good pictures of each type of block. It also has good charts and explanations of how to use the blocks to adjust how wide/narrow the a-ams will be mounted. The website also has good pictures of the different suspension block spacers that you can buy. Tamiya has done a really good job of keeping this part of the car universal between many of their different models.
If you scroll to the bottom of the page, you will find a chart that lists which blocks will work different Tamiya chassis. If you have access to a printer, I would highly recommend printing this information out.
To answer your specific question (according to the chart) it looks like the new one piece adjustable mounts should fit a TB03, but the new split adjustable mounts won't. After downloading/looking at the TB03 manual from Tamiya, you should be able to see how the mounts would work. Here is a link...
https://www.tamiya.com/english/rc/manuals.htm
I hope this information helps.
One other quick thing to note. The older V1 style splits blocks probably could be used on a TB-03, but there would only 1 screw securing them to the chassis. Since I've never owned this chassis, I can't offer much more advice. You should check out the following thread here on RCTECH.net...
Tamiya TB-03
Tamiya TB-03
