Exotek F1ultra
#992
#993
Dup
#994
My friend send me a result from some tests
#997
3 things I did wrong on test n tune day 1.
1. Too much dual rate, I was hitting the stoppers. Front suspension was not so smooth in the corners. Mike R thank you, not sure I could figure this out alone.
2. Battery stopper moved and was barely touching one small spring. Not easy to detect unless you look for it.
3. Needed a tiny gap in the rear diff to allow for play so the diff can work smoother.
#998
#999
#1000
#1001
R/C Tech Elite Member
#1002
another option is the Fenix MK2 gear diff. it has a titanium axle -- https://www.sidepieceracing.com/DGD-MK2
#1003
Search - Gear diff spur
Diff clamps onto solid shaft. Watch their assembly video -
#1004
I thought the fenix gear diff was an oil filled diff...I guess they have special grease for the gears...
#1005
question:
may fit this one? on pic is the same!
https://www.arrowmax-rc.com/products...shaft-steel-v2
