Like Tree1188Likes
wtcc's TT-02 KR
Old 04-13-2019 | 12:09 PM
  #181
jag88's Avatar
Congratulations ! Beautiful work !
wtcc likes this.
jag88 is offline
Old 04-14-2019 | 09:36 AM
  #182
wtcc's Avatar
I was diligent again
First I was excited to finally make a befitting lipo mount to get rid of the tape and and the lexan angles I used up to now. It is definitely an easy solution consisting of two L-shaped carbon fiber parts with two holes to mount them on the backbone of the chassis just underneath of the drive shaft; and one hole on the other side to mount a small post and the small carbon fiber plate (this part is doing its job since I bought it from Reflex Racing for my TC6.1) that holds down the battery:
And then I installed the dust covers. The fitting is nearly perfect, but I am sure dust will find a way. If it keeps out sand and stones, then I am happy.
Again the rear differential needed a full service. A mix of green slime and oil was pushed out and all over the left side of the car. I had enough of this and cleaned everything. I took an 8mm drill, widened and deepened the O-ring hole. Then I took Xray shock O-rings and slipped them over the outdrives. Lets see if this will solve the leaking from the outdrives.
wtcc is offline
Old 04-14-2019 | 06:42 PM
  #183
WTCC that is a professional looking car!
I have been reading this thread really enjoying the evolution of your project!
Also so cool to learn about having CF parts made from CAD file.
Next year Tamiya Mini Cooper
MatsNorway and wtcc like this.
CedarCityJohnny is offline
Old 04-15-2019 | 11:25 AM
  #184
wtcc's Avatar
Last time out, I made video of the third run I made:
I think despite the lower grip level it is visible, that I can take more speed into and through the corner, and that the car stays flatter and/or is less rolling.
wtcc is offline
Old 04-16-2019 | 12:45 PM
  #185
wtcc's Avatar
Gregor and I went to Dasing today. A beautiful weather greeted the whole day. The sun was strong, but the temperatures didn‘t went up to high. We had 17 degree Celsius air und 29 on the track surface.
I definitly had too much to test and learn today. I tried different bodies, tires, springs and camber adjustments, while relearning this track.
I rediscovered the picture wall of clubchampions and got reminded of the three championships I won here before.
The good rhythm came around lunchtime. The car was not as easy to drive as I hoped. My last serious outdoor season was in 2015 and I had to adapt to the low grip surface. Which I have successfully done now. The car was good in all corners, but needs more steering in the corner entry for my liking. I think I will try softer springs next time. Body roll wasn’t a problem event without a.r.b. in front... So much to try... I need to make a good plan.
The dust caps worked like charm. Fine dust found its way, but sand stayed out.
wtcc is offline
Old 04-20-2019 | 10:36 AM
  #186
Get those shocks anodized black or blue
Juan Aveytia is offline
Old 04-20-2019 | 10:30 PM
  #187
Nicadrauspro4's Avatar
Agreed. Or change to Tamiya SSBB.
Nicadrauspro4 is offline
Old 04-21-2019 | 04:13 AM
  #188
jneezie3000's Avatar
It's a project car. He has done amazing work on this car and all you can see is the colors on the car. He has poured hundreds and thousands into this project, much less all of the enginuity that none of you possess. You so-called racers are so basic and un-sophisticated... The shocks are readily available and have the lowest center of gravity. Call Tamiya and tell them to get to work! You won't see ULP shocks from them for 5 years. By then we'll have moved on to awesomatix/ serpent style setup!
Slo_E4 and NutDriver like this.
jneezie3000 is offline
Old 04-21-2019 | 05:43 AM
  #189
I have read and followed this thread and have seen the development, improvements, genius ideas executed and great designs. So it's not just the color I've seen. I only suggested the SSBB shocks to match the color of this already beautiful kit and nothing else then here you come insulting the rest that none of us posses any ingenuity (NOT enginuity).
Next time you insult someone, make sure you already know how to spell. Otherwise go back to preschool first. :P :P :P
jneezie3000 likes this.
Old 04-21-2019 | 09:16 AM
  #190
wtcc's Avatar
Please, don’t attack each other.
I would love to get rid of the orange, but also need to calculate if it is worth the money and probably the problems a color change could cause (fitting tolerances). Up to now I don’t have a high quality elox guy on my hands and also need the car for tests and upcoming races. If I get a chance to change the color, I will. Right now I am happy that the car works and need to bring it up to speed outdoors.
Speaking of it: Tomorrow I will visit Dasing again and try different setups. My two or three year old shorty lipos got replaced by new R1wurks lipos. Mainly I am looking for corner entry speed and off throttle rotation. With Florian Botzenhart a very experienced development driver will join Gregor and me tomorrow. He will need to answer a lot of my questions
wtcc is offline
Old 04-21-2019 | 09:29 AM
  #191
Wtcc is focused on performance, which is the only thing that counts. All the other color stuff belong to the phony pageant world...
Marcos.J likes this.
bertrandsv87 is offline
Old 04-21-2019 | 10:14 AM
  #192
Man you need to lay off the caffeine. I don’t need to repeat everything everyone has already said. The project is extremely badass. You must not be a Tamiya faithful. You can’t roll a Tamiya with Xray orange. Have a sense of humor.
Old 04-21-2019 | 10:16 AM
  #193
i had xray shocks anodized in the past. Everything worked great. By chance are you going to sell these parts to the public?
Old 04-22-2019 | 11:26 AM
  #194
wtcc's Avatar
Thanks for the info!
I had an outdoor day with a happy end. I was consistently three tenths faster than the last time. The track had a similar grip level. All my ideas worked in the beginning. Then I worked in the wrong direction for a few runs, but found the way back on the right track.
Today I could attack harder into the corner and had a little more rotation. For the last run I found something that brought more traction for the front end, made the car faster and nicer to drive. It felt really good to hear the time announcing voice to start with 16 every lap. My fastest laptime is now 16.495s With ten and more laps in the 16.6s and even after nearly 15 minutes I could stay below 17s. That was a solid step forward and made me very happy
With that good feeling I will rebuild and check the car next week and hope to deliver a good performance next weekend in Erlangen.
wtcc is offline
Old 04-22-2019 | 12:39 PM
  #195
wtcc's Avatar
My friend Gregor did a lot of filming on the first outdoor running last week. He now made an amazing video of my car. I am speechless of his skills and talent. He published it on Youtube just minutes ago:
wtcc is offline
