T.O.P. Racing "Scythe" 1/10 EP Touring Car
#722
No major changes to the car just a few upgrades. We all ran the 08 kit. Jason, Vincent, and I used the 3.5mm chassis while Josh and Niels used the carpet flex pro upgrade. Josh also had a chassis with the batteries more forward which is desirable for foam tires on carpet. All of us used the 17 tooth upgrade center pulley.
#724
If you get a chance, get the alum diff (replace the thrust bearing with a tamiya or cyclone one) and some carbon fiber arms.
The kit springs are really good for asphalt.
#725
E.J
Yeh i've got the Alloy diff, kept it from my previous Scythe, and i've got a Tamiya thrust bearing in it. More or less Updating my chassis is all
You say to get some Carbon Graphite arms, wondering what effect they have on the car???... do they increase responsiveness or something along the lines of???
My first time out in the car last year though, the kit springs understeered like there was no tomorrow, however i had changed front drive to a spool, i'm assuming you meant kit springs work with the original one-way?...
I've a set of HPI springs coming also, have to start trying to convert from the TOP springs.
Do you run the Low profile shock towers or standard???...
Sorry to ask so many questions, but thanks very much for your help thus far, its much appreciated. I'm still getting my head around this car, coming from Xray.
Cheers,
Robbie
Cheers,
Robbie
#726
Hi Robbie,
#729
Hello Everyone,
I finished 5th in stock and 3rd in 19 turn. Stock I had no motor, but in 19 turn we ran brushless where speed was more equal and it showed the potential of the car.
I want to congratulate Jason Ertrachter for also making the main in both 19 turn (outlaw) and stock rubber. I think Jason had a chance of winning in both classes!
Jason and I ran similar setups, HPI Gold springs up front and HPI Silver in the rear. I'll put a setup sheet together and post it, the car was dialed. Not sure what Kenny's setup was, I think it was pretty close to ours. His car was pretty good too.
I'm putting together a press release for Josh, should have it up here in a couple days.
HVAC25000, I replied to your email. Sorry for the delay.
I've decided to make the old X-ray T-2 a Trans-AM car and get a new electric car. This one caught my eye but some concerns I have is the price of the kit and spare parts. I alos wonder when they'll be available in a timely manner..
I did check the use webpage and the "coming soon" news was on it....
#730
I also was at the birds and spent a lot of time looking at Josh's car....
#731
E.J
Cheers,
Robbie
Cheers,
Robbie
On high bite surfaces I think the harder arms are more consistent and easier to tune.
I use the kit springs with both a one way and spool with a lot of success. Last year Marc Mendoza finished just outside of the A at the Reedy Race. His car was very good and used the kit springs (running a spool).
I usually use the low profile towers with our springs and the stock towers with all other springs. At the birds I was able to use the low profile towers with HPI springs because Josh gave me some different spring retainers. But even with these retainers I was only able to get down to 4.5mm ride height.
I'll post setup later today.
#732
Shoot me an email at [email protected], I can address some of your concerns and questions.
I'm looking at 3 cars and I really like the design of the Scythe car.. And I should thank Josh for taking the time to talk about it at the birds... He was one busy person but took the time and effort to answer any/all questions I had....
#734
Hey Robbie,
Also if you get some HPI shock part trees, you can use the HPI shock bottoms and retainers, you will have no problem using any type of spring, even with the lowered towers.
#735
I presume this is Cyruls car.
http://www.rc50.com/modules.php?name...bum=49&pos=375
From what i can see:
Kyosho Shocks
Different rear arms, Kyosho
Front knuckles, if not the whole arms are different, look like xray?
Machined the camber link mounts on the bulkhead caps, to lower the top link.
I wonder why the kyosho stuff was used, is it just cause he was comfortable with them from the old cars? Josh, saw you lurking around earlier, care to add?
Kyosho Shocks
