TEAM ASSOCIATED DB8
#154
has anyone out on a different body?
#155
bump
#156
what platform does the nomad share with other associated vehicles? the 8te? im wanting to get some lower body mounts and was thinking the ones from the truggy might git?
#157
what is your folks race track set up as far as tires, shock oil (placement of shocks), camber link placements, and diff oils.
Thanks in advance
Thanks in advance
#159
anyone else splitting the front inner hing pin inserts? ive done it like 3 times now.
#162
i thought about getting those mounts but just havent yet. you guys running the stock cage and body? part of me wants to try to mount a truck body on it...
#164
Oh no i was thinking a totally different truck body and not the sc8 one. how ever not many truck bodies that are 8.5" wide. id have to go truggy or shortcourse body to make it fit.
#165
Shortcouse body you would have to shorten chassis. There is a hpi body that also fits, and I think it works with sc8 cage, but it looks a lot like the sc8 body iirc. To run truggy body you would need different shock towers and mounts, unless you just did custom mounted and didn't use rc8t parts.
I've ran factory team and stock mounts a lot over the years on associated vehicles that use these same mounts. I really like the factory team mounts, but for bashing I prefer stock mounts. If you crash and cartwheel or hit something it tends to crack and break the factory team aluminum mounts. With the stock mount worse case it normally bends, and you can bend it back several before replacing.
