4wd stadium trucks!
#91
https://wheelsnwings.wordpress.com/2...iler-and-wing/
To me it would be silly to exclude wings, however I can see the need for some tracks with Astroturf to require Lexan wings instead of the stock plastic wings to help protect from tearing the turf.
I don't see any restriction for number of shocks
#92
i just dusted off my crt.5 with the rc-monster conversion. Planning to put updated electronics as the the old feigo 10l and mamba esc are dated. Tearing it down to freshen up the oils and look for broken parts. Also want to see if a t5m body fits. I miss my converted optima mid from the 90s
#93
Always wanted one of those crt.5's; never ended up with one though. Have searched often for them but never much luck. I hope you're enjoying it!
As far as I can tell, the 22 SCT 2.0 rear end (arms/driveshafts/hubs/hingepins[outer]/tie rods) can be adapted; just waiting on my Xrays to sell.. have 3/2 more in parts. Who needs an XB4?! kidding. (not really but I'm not allowed to post stuff for sale here yet. Doh!)
#94
I don't think they specifically say "no wings allowed", though I believe the term Spoilers and Wings are often used interchangeably as explained here:
All I see is a minimum weight of 1814g, there is no mention of a max weight
#97
Super Moderator
Trader Rating: 31 (100%+)
IF a true 4wd ST class were to come to birth. I would want and expect it to look just like it's 2wd little brother. The same way 2wd and 4wd SCT do. A 4wd ST shouldn't be a mini truggy..crazy cab forward body, buggy style wing, ect. Let alone SC wheels/tires or anything else besides the current 2wd ST wheel and tire combos.
IMO
IMO
#98
I completely agree with what I quoted. Keeping the true 1/10 2wd st look while gaining 4wd is the only thing I'm out to accomplish. One thing I've personally even been confused over is even if it doesn't use a buggy wing/mount, if said vehicle is derived from a buggy (especially a 3 diff platform) will it be a 1/10 truggy or 4wd stadium truck? I've been wondering is the wing so much of an issue as to make it a different class? I've set a wing/wing mount atop the t4 body on that Xray and it looked... Mean. Idk. One thing I know is that I will personally be sticking with 2.2 wheels and tires/2wd wheelbase/width approximately.
#99
The main difference is that stadium trucks lack parachute bodies which could soften landings. Other than that, I suppose they're fundamentally the same -- but then, so are 2WD stadium trucks and SCTs, yet people still appreciate both styles of vehicles.
#101
All this talk is reminding me of what bodies/wings were allowed in the USGT/VTA classes all over again, things got so far out of hand that they started listing specific product numbers on an approved list and then the local RD started excluding some approved bodies at the national level because he felt they weren't in the spirit of the class <facepalm> I personally would want to avoid this headache and just go with the ROAR rules already listed.
Wheel selection is straight forward, and technically the Hyper 10TT "wing" fits within the measurements of the "spoiler" so I'm not seeing any problem there. Cab width/height requirements are also satisfied, there are no restrictions on where the cab may be placed. The ROAR rules are simple enough, no need to add extraneous restrictions, folks just need to come up with more creative ways to get ST wheels to fit when doing a conversion, simple as that.
#103
Seems like a Kyosho DBX VE would be a good conversion -- small knuckles look about the same size as Hyper TT knuckles, 1/9 scale is a little bigger than 1/10 buggy.
#104
Originally Posted by DBX SPECIFICATIONS
Length: 18.7" (475mm)
Width: 11.8" (300mm)
Height: 6.1" (154mm)
Wheelbase: 12.6" (320mm)
Perhaps you might be able to shift the electronics around on the chassis and shorten the wheelbase/length by 35mm with a shortened center shaft and that might be doable:
#105
Good find on the specs, thanks for figuring that out.
