Tekno RC EB410 Thread
#2866
Not the ideal place for 10th scale. These are tougher from what my friends are saying. I will get mine from the next Tower shipment.
#2867
I could run similar lap times between the two, but they drove very differently. The b64d was best driven like a 2wd buggy. Brake while going straight before entering the corner, roll through, and then gradually accelerate as you straighten out. It makes it very easy to switch between my 2wd and 4wd during a race day. The 410 just wants to be on power all the time to get the same lap times. I would brake just like the b64 on the straight, but then as soon as I started turning I would be back on power.
#2868
Has anyone experimented with the b64 slipper in the eb410 on clay indoor or outdoor and what have you learned from it?
#2869
I drive a B64d and have test driven a friends EB410. Just from a durability standpoint for your track and conditions, get the 410. If you want it to handle like your B64d, it can be done. The biggest thing is matching the weight bias.
#2870
#2871
there is a running video of the two racing.
https://www.youtube.com/watch?v=2ipmLajln94
I think the tekno driver was being nice!
#2872
Back ordered mine. I have a Tekin 7.5 and plan on using it with the RSX, but might go with the 6.5 Spec R motor. I am glad it handles more like an 8th scale buggy, sounds fun.
#2873
See this post for details (also posted on petit rc setup page).
#2877
#2878
In my first day out with the tekno I was able to do much faster and consistent laps than my b64d. Only broken a rear camber link on thr tekno. Vs multiple arms, front dogbones, shock shafts, shock caps on the b64d.
#2879
My understanding is that if you do this then you'll need to go with thicker diff fluid to compensate the missing friction from the 2 planetary gears.
I would be more interested in learning if anyone has found some plastic gears that might be compatible from another brand?
#2880
For reference the metal tekno gears on plastic crossbar weigh roughly the same 3grams the B64 plastic gears with metal crossbar do. I know xray coomposite/plastic gears dont work. Tekno is already pretty solid from a reduced driveline point of view.
