TLR 22 SCT 3.0
#526
Sorry, I must of misread that, just finished up with the listed setup above. We run this as an entry class on touring nights. I did add 2mm of limiters to the rear and 4 to the front. Ride heights around 16mm.
Question, for you or Frank, how low can I go before the geometries get a little wonky. Some things seem close right now??
#529
This question is for everyone who is currently racing their truck what torque rating does your preferred steering servo has as well as it's transit time from side to side?
#531
#532
Hi-
Im still trying one thing at a time. I forgot to mention that the truck turns very fast through "S" turns. I am trying to preserve this behavior.
I wonder if there is not enough roll/suspension travel in the truck to absorb rollover? Also would spike type tires be less aggressive than pins?
#534
I am currently running the ball diff in this truck. How often do you all rebuild the diffs? I've heard some say that for the rings, they just flip them over. Is that okay to do? I'd think new bearings would definitely be needed in case they have wear spots on them keeping them from being perfectly round.... correct?
#535
I typically flip the rings and use both sides before replacing. Balls get replaced every time.
#536
Cool. Thank you very much. Looks like a diff rebuild is in my near future.
On a side note... does anyone run a gear diff in this truck?
#538
Looking over most the setup sheets. It seems most are running much higher ride height than most cars/trucks I've owned before. Why is this?
#540
Has anyone tried to put in a laydown transmission into the truck??
