TLR 22 SCT 3.0
#976
5.0 Rear Hub is needed with a 6mm Hex to get back to the correct track width using a +3 Hazard Wheel
#977
Do not need anymore
Just sayin
The AE set up worked very well.
Just sayin
#979
Picked up the new RCLYFE 5.0 Front Tower for Buggy Shocks. Found a used set of Avid 13mm shock bodies to convert the rear buggy shocks on all 4 corners to F&R buggy. I assume this will help control the body roll and keep the truck more level in turns.
What spring is recommended for the buggy front shocks?
#980
#981
#982
For clay you don’t need the buggy front tower conversion.
#983
#984
Thanks! Waiting for Willspeed spring to come.
I checked my setup sheet and was running AE V2 Blue 54mm and Yellow 61mm.
Now that I switched to buggy fronts on one of the trucks I changed to AE V2 Orange.
AE V2 Orange Fronts and Yellow Rears is pretty close to Willspeed Blue Fronts and Green Rears.
