TLR 22 SCT 3.0
#436
Looking for a good turf set up, is there anything posted online anyone likes for a good starting point?
also I got the new style aluminum diff, should i start out around 30K?
#439
Hey guys, I'm looking for a short course truck. I'm trying to decide between the 2.0 and the 3.0. The 2.0 is about 120$ cheaper, but it's also rear motor and I'll be on carpet for a while. Is the 3.0 worth the extra money?
#441
Anyone have advice for carpet setup
#442
I ran my 3.0 this past week at a club race for the first time. It was a large outdoor track with these conditions. Dry, very loose, very bumpy and had a 15mph wind. I ran the box setup to get an initial feel for the truck. I did not run any sway bars, ran the ball diff and three gear transmission. I qualified 1st and made a few changes on the radio with steering and adjusted the ride height was all I did for the main. I had not cut any vent holes out of the body so in the main I parachuted the first jump and feel back to last. Worked my way back to 1st and stayed there until the finish. The truck was real fast and jumped nose up but I am sure it had to do with the body lifting it up, I corrected that with brake. The next club race I am going to try the four gear transmission and gear diff and also try a thinner shock fluid. I think this truck will be very good once I get use to it and get a outdoor setup nailed down. I have not driven a TLR 2wd SCT since the XXXSCT about six years ago. Much Improved!! lol
#443
a couple of the things I did and my truck was extremely good on carpet.
dirt laydown with carpet +3.5 hubs 0 shims inside 2mm on the outside
Durango light brown front springs, super hard.
TLR yellow regular springs
pink sway bars front and rear
wedge front tires with outside and inside wedges dremeled off
rear mini pins with inside and outside rows of pins dremeled off.
2 degrees of toe with 2 anti-squat
TLR gear diff with 60k
19-20mm ride height
These are some of the things off the top of my head and like I said my truck was extremely easy to drive and good. Haven't ran it on carpet since it won the championship but when I did it wasn't like you would think a SCT would feel on carpet.
19-20mm ride height
#444
Cool! I'm ordering my car hopefully today so once I get it together I'll probably start tinkering! It says I need a 48 pinion, but I'm not sure how many teeth to get. Any suggestions for a stock setup?
#446
#447
#449
We're looking into this. We didn't see any breakages in testing, and didn't really hear about any until the last week or so.
As a temporary fix, you can glue the inserts in. This way, you'll have both inserts working together making it twice as strong - although you'll lose the adjust ability.
#450
19-20mm ride height
19-20mm ride height
