TLR 22-4 2.0 Race Kit Thread!
#2402
Sorry I couldn't get back sooner, I'm not able to be here daily.
For me, A ackermann has a wide outer wheel angle, and causes the front end to scrub, which can give more weight transfer and steering, but in a not so natural weight, and it becomes very speed sensitive. B is closer to true ackermann (little scrub), and rolls through the turn much better and is a lot less speed sensitive.
The C ackermann setup gives you an adjustable link so that you can adjust the ackermann as much of as little as you'd like. Most all of the team runs the standard aluminum ackermann parts in the B location.
thanks.
#2403
#2404
It makes a noticeable difference. Rear grip is improved and more consistent. You can also setup for more steering without the car washing out.
#2407
Spmss6240
Ok soo have purchased and installed the ss6240 servo, haven't run it yet but tried it on the bench and it's lightning fast, also purchased the 22 5.0 rear arms, will test it with new servo before installing the arms, also made up a cf wire holder across the front of the servo which passes under the servo linkage and ran another piece of cf to mount the top fan onto, it pivots out of the way if you need to remove the motor.
#2415
Things on a wishlist for a new car would be bigger teeth for the front belt like the schumacher car. Keep it possible to make the drivetrain sealed for oldshool dirttracks, like it is now. Turfdrivers I've talked to complain about lack of steering and skipping belt. Find some way to make it drive like a rear balldiff car with a geardiff. I doesn't take long to rebuild but it would be nice not have to do it at all. It gets gritty after about 6 runs with a mod motor. Otherwise, I really like this car. It's supernice to drive!
