RC8T3e
#511
I recently picked up another center diff and was surprised they removed that washer. I figured if anything that washer helped protect the o-ring and create a better seal. If your hearing a crunching sound check your diff and pinion, you may have some wear. Theres some great videos on youtube on how to shim a diff.
Anyone having problems with bending shock shafts? Just wondering if its a material issue with Associated, I'm seeing allot of it this season.
#513
Built my truggy per manual with updated diffs. I'm getting a crunching sound under hard acceleration only. The pinion lash in the diffs feels tight. It is only under hard acceleration and not while braking. Any ideas? There are no washers between the diff case and the pin that holds the axle under the sun gears but that is what the book showed. They seem to have a lot of slop.
#514
On AE's site there is a supplemental diff instructions. The build is completely different!
#517
I run a 2250 but you definitely don't need that much motor. The 2000kv will be plenty. Hell my wife is running a 1900kv buggy motor in her T3e.
#519
I realized today that my EPA was at 90% and I wasn't hitting WOT so I'd imagine the 2000kv is probably better fit.
#520
I can't post a for sale ad for some reason but I have a brand new in box kit RC8T3E if anyone is interested. Pm me $375 shipped
#522
So lately I've found that the closer to box settings the truck gets the better it is. Is that the general consensus? The only changes I've made were 10/7/7 in the diffs and 40# in the front with yellow spring and 35 in the rear with a blue spring. I think now I need to take a bit of roll out of it.
#524
what would 30,000 diff fluid in the middle do to the truck more wheel spin? compared to 10,000?
