TLR 8IGHT-E 4.0 Kit Thread! >
Like Tree36Likes
    Hide Wikipost
Old 06-17-2016, 07:39 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8IGHT-E 4.0 Kit Thread!
Last edit by: Kraig
Welcome to the 8IGHT-E 4.0 Wiki
USEFUL LINKS
Overview
Manual
Pictures
Parts
Print Wikipost
Old 12-26-2018, 04:49 PM
  #1216
Originally Posted by Furadi
Sounds really weird. I'd love to see video. You really shouldn't have to deviate from the stock setup just to land jumps.
I'll see if I can setup my phone on the driver stand tomorrow and get something. Maybe it's just poor technique and getting used to a new to me platform .
Furadi likes this.
TxLoser is offline
Old 12-26-2018, 08:05 PM
  #1217
What track are you running at? If your at mikes I'll be there Saturday and I can help you setup I'm also running a 4.0
I'd try 37.5 front with 1.2x8 pistions 103.5mm droop, ride hight of 26mm
and 35.0 rear with 1.3x8 pistions 114.0mm droop, ride hight of 27mm
is a good starting point for mikes in porter
brewkett is offline
Old 12-27-2018, 07:15 AM
  #1218
Thanks for the offer, but running at Indy up in the Dallas area. Good suggestions on the wt and pistons. Similar track type from what I can see though I've not been down there .
TxLoser is offline
Old 12-27-2018, 04:28 PM
  #1219
Shock oil, driver technique, and a little drag brake seemed to have helped today. Car ran great and I think I've worked out the assembly induced bugs. Now I can focus on just driving and getting better with it.
TxLoser is offline
Old 02-27-2019, 04:45 PM
  #1220
Officespace's Avatar
Default Best Ebuggy Body to fit a Converted 4.0 nitro buggy
I just got a new 8ight X nitro buggy and will be converting my old 4.0 nitro buggy and I was wondering what body would fit the best on the electric converted 4.0 nitro buggy? I’m really primarily a nitro racer, but I figured I’d convert my old nitro buggy to electric for now because I have at least a few thousand dollars worth of new 4.0 parts I’d like to burn through before I get an XE.
Any body suggestions you guys can give me would be greatly appreciated!
Officespace is offline
Old 02-28-2019, 03:07 PM
  #1221
I would go with a J concepts 4.0 s2, 3.0 silencer or the 4.0 bittydesign force.
fantomdude is offline
Old 03-04-2019, 06:37 PM
  #1222
4.0 kit is on sale on tower hobbies right now for $400
rcuser123 is offline
Old 03-23-2019, 06:57 AM
  #1223
I’ve run my 4.0 now since December....great buggy. I really like it. Two issues though that keep coming up for me. I’ve had to do a lot of body work on this thing to keep it going. The rear mounting post broke through the body to the aft early on. The front came apart a bit later. Shoe goo, dry wall tape, and some lexan from an donor SCT body have kept working for me. Aside from not crashing, any suggestions on this? Also what is the purpose of that little clear piece that come with the body? It obviously is for the front of the body but I can’t see it’s use.
Second is the motor mount. Red locktite and that sucker still get lose on my after a few runs. I know to check it now before each race, but seems like it should hold a little better.
Thanks.
TxLoser is offline
Old 03-23-2019, 07:06 AM
  #1224
nitro_mt_racer's Avatar
Trader Rating: 241 (100%+)
Over the years we learned to space the rear body mount forward. Just need a longer screw and some washers, a nut, fuel tubing, just something to fill the space. You want the post to the front of the rear body mount hole so when the chassis flexes it has room to move. I also slot the front hole in the body.
nitro_mt_racer is offline
Old 03-23-2019, 07:12 AM
  #1225
Quick response. Thanks. I’ll look around and see what I can cobble together.
TxLoser is offline
Old 03-23-2019, 04:35 PM
  #1226
body has always been my complaint seems to crack pretty easy shoe goo and drywall tape has also been my fix or whenever I buy a new body but as the motor mount not had a problem maybe a quick suggestion try putting a support under the motor I’ve done that in the past on other rc cars and it has help from the motor coming loose other than this buggy is great thinking about getting the new losi buggy but not cheap lol
mavdriver is offline
Old 04-08-2019, 10:11 AM
  #1227
Furadi's Avatar
Just picked up a new to me 8ight e 4.0! Already put about 20 packs through her playing with the suspension and thinking about trying the EVO springs here soon.
Furadi is offline
Old 04-11-2019, 09:19 AM
  #1228
ceh329's Avatar
Does anyone run a fan in their 8ight e 4.0. I'm just moving over from 1/10 and we all run fans. I don't want to cook a new motor just in case.
ceh329 is offline
Old 04-11-2019, 11:28 AM
  #1229
Don't need a motor fan if you're geared correctly
Old 04-21-2019, 10:14 AM
  #1230
Furadi's Avatar
First race with my 4.0. Running the EVO springs. Got the new MIP bypass kit coming tomorrow.
Furadi is offline
