TLR 8IGHT-E 4.0 Kit Thread!
#1186
[QUOTE=rhodesengr;15346003]
I have an Xerun 4268 SD G2 1900kV. IDK how many turns it is as they don't rate the 4268's that way. I am running the 14T pinion which is the suggested pinion for Outdoor on the setup sheets for the 4.0.
I`m running the same motor go up a tooth for outdoor set up it runs nice and cool no problems , on cool days like 70 degrees and below i run a 16 tooth 14 tooth is a bit under geared for that motor unless you are running in a tight or small track
#1187
Just picked up one of these kits. I was under the impression it came with fluids in the box. Mine does not seem to have them.
Nevermind. Figured it out.
#1189
Just got this kit a couple days ago, and the build is nearly complete. All I've got left to do is to secure/solder the electronics, paint, and glue tires. All went well except one thing. I can't for the life of me get the #25 servo adaptor thing to go over the splines of my servo. It's a savox, so I know I'm using the correct piece. Is there a trick to getting this to fit? I can get it just on top of the splines, but I figured it should slide over the top of them and sit flush on top of the servo.
#1190
#1191
You could try buying more and hope they fit more to your liking: https://www.amainhobbies.com/losi-me...a99043/p166668
#1192
Problem solved. I found a Protec aluminum servo horn in my spare parts stuff. Perfect fit. Easy on easy off.
I'd say some quality control on parts sent with this would be good. I was missing a couple screws. Even got one screw with no threads. This is only my second build. First was Tekno, and I'd say they have the market cornered on well written instructions, and diagrams. Also, no missing screws. That being said, I did like the way this one went together. Just took a little more brain power. Only a little.
My next issue is the ESC. On my Tekno I was able to zip tie it to the plastic mounting plate in case the tape failed. I didn't trust just the double sided stuff. How do you secure your ESC. Just the tape?
#1193
I drilled and counterunk the chassis so I could mount a Tekno ESC tray on my 8ight and since it was a Tekin RX-8 I used screws to mount it to the Tekno tray with shock O-rings between the ESC and the tray and then Tie-wraps to hold the ESC to the tray in case the screws came loose LOL.
Tekno tray I used is this one: https://www.amainhobbies.com/tekno-r...r45005/p191294
#1194
ESC: I am just using the 3M 411 tape. No problems so far. I have used this tape for years to mount FBL controllers on helicopters and never had one come off or get even the slightest bit loose. Of course these buggies bounce around much more than any flying model.
#1195
Here's the finished product. Mostly... Need a battery, 15t pinion, and some reaming to losen the steering. Running an XR8 SCT Pro and 1900 hobbywing combo.
#1196
I just slapped my esc to the chassis with good old servo tape (Picked up gorilla tape from wall mart) Never have had an issue with it coming loose.
#1197
The red Servo tape is what I ended up doing. It actually feels really secure. I'll just check it after a few run/crashes .
#1198
Are you guys running the shock boots? I've got them on my SCT, and they've gotten a bit torn up. I did build it with the CV boots, but may even remove those.
#1200
Thanks. I'll put those on before I run it.
