TLR 22 3.0 Race Kit Thread!
#677
Which servo spacer should be used for KO servos? 2,1, or .05
#678
#679
Ok, so I just went back and threw a light weight 2s LiPo in 3.0 and it fit. The plastic parts that stick down from the battery are just long enough to provide some support to keep the battery in place. Obviously, you'll still need to put a foam spacer on the the brace to help keep everything tight. I also weighed my car at 1508g. This is with the 1mm axle spacer and the 22-4 front inner hinge pins.
#682
My car felt better in the mains than in qualifying and the lap times agreed. I am not 100% sure why but here is one possibility. I discovered during the break between heats that there was way too much rebound in my shocks and I re-bled them. When I built them there was maybe a millimeter of rebound. When I checked them before the mains there was at least 10mm. Can someone explain why this happens? Is it air accumulating over time? Thermal expansion?
Did you refill with oil and then bleed them, or did you bleed out what was already in there? I refilled mine and had to bleed them a couple times to get minimal rebound, but am left with some head space that concerns me.
#683
I've done that. I went over the windows with black sharpie. If you want to get creative you can draw angry looking eyes on the front windshield. Make it look like an angry bird.
#684
With the new front hex, does the buggy use the same wheels as the B5m front and rear?
#685
Quick question for anyone with experience with the 22-2 aluminum hubs. I bought the aluminum hub set, pretty sure it is the one for the 22-2 as it does not match the 22-3 stock plastic piece camber holes. Which direction should the TLR logo face? It appears to need to face rearward but want to be certain before installing and having to do it over again.
#687
Does anyone know why the little spacer was added to the front axels between the bearings? they event needed in previous buggies, wondering why now. Im sorry if this has been covered somewhere but i haven't seen it.
Fasttrak, the logo on the alum rear hubs faces towards the back……
Thank you…….
Thank you…….
#689
Thank you…….
Thank you…….
The spacers are there to keep from binding the bearings and has been the case for every vehicle I have built for many years. It keeps from putting lateral load on the bearing which will cause them to bind and wear out very quickly.
#690
Front wheel off-set is WAY different.
Thank you…….
Thank you…….
