Xray XB2 2WD Buggy Thread
#963
*proof reading new XB2 Dirt Edition manual*
Looking really good I must say
Bent
Bent
#964
Hi Bent,
Sorry for off-topic, but i want to send my congratulations to Malin (and to you too), for the a-main in 4wd at DHI Cup this past weekend, well done!
#965
#966
Location: El Pueblo de Nuestra Seńora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 40 (100%+)
My car has been getting better and better. 7.5 mod xb2 on medium clay track
It's actually drivable and forgiving now. car didn't work at all out of the box but these changes made a huge difference, car responds very well to changes!
I don't know much about setup but I was able to get help from a variety of people.
So far what i've done from stock setup is:
lengthened rear links
moved rear shocks to the back
shortened wheelbase at the rear
removed several chassis flex screws
reduced rear anti squat
increased rear toe in
#967
18 is as low as I can get it. I'm thinking something else must be wrong but can't see anything. Rebuilt the shocks and they are super smooth (polished the shafts), and there is no bind. Arms move freely, I dont know what else to check haha.
Rear end is 1.7x2/35wt Associated oil 27mm stroke, 3mm upstop, 1mm downstop
#969
Rear end is 1.7x2/35wt Associated oil 27mm stroke, 3mm unstop, 1mm downstop
If you are trying to get to the 16mm front and 15mm rear ride height we are using we cut 1 row off the springs.
This applies to both 4 dot front / 3 dot rear and 3 dot front / 2 dot rear setups
Bent
#970
#972
Bent,
I´ve a question according to the hard and medium parts. When I use the medium parts in front, do I have more steering or less? Or does it only change the "feeling" of the car?
Furthermore do you have already a release date for the brass lipo weight?
Thanks a lot in advance!
PS: Congratulation to the great results at DHI Cup!
#973
- added more rear droop( no inner spacers and unscrewed shock end)
- took away front droop (3mm internal shims)
#974
bentka, we run on medium to high bit dirt tracks. Which version would you recommend one track pure clay and pretty tacky where worn out clay compond works best, the other is clay mix with medium traction we currently run super soft slicks. I am leaning toward the dirt, thanks for input you can provide
