Xray XB2 2WD Buggy Thread
#5523
Heavier rear diff fluid takes away off power steering.
#5527
Any news about a 2018 dirt edition?
#5530
finding the magic spot in this is the key..
Diff fluid has nothing to do with traction of the car.. only the driveability of the car. too light of a diff.. and the car will feel loose both on and off power, too heavy of a diff and the car wont go around a corner, and push on power.
#5531
#320900 Complete XB2 Dirt Rear Suspension Conversion Set
• Complete conversion set
• Convert XB2’18 Carpet into dirt car
• Generates more traction
• Increases stability
• Used by factory team
Complete rear suspension conversion set including ball differential to convert XB2 Carpet 2018 version into a car suitable for clay tracks. This conversion set includes wide rear suspension arms from XB4 kit as well all other parts necessary to upgrade the car into the specs as used by the factory team as well Ty Tessmann at the recent Reedy Race.
Includes:
#323325 Alu Rear Longer Lower Susp. Holder - Narrow - Rear (10mm)
#323353-M Composite Rear Upright - Medium
#325002 Ball Adjust. Diff for 2.5mm Pin - Set - HUDY Spring Steel™
#325323 Rear Drive Shaft 71mm with 2.5mm Pin - HUDY Spring Steel™
#327310 Rear Suspension Pivot Pin 3x46 mm (2)
#363111-H Composite Suspension Arm Rear Lower Right - Hard
#363121-H Composite Suspension Arm Rear Lower Left - Hard
#365357 Alu Wheel Hub 12mm - Offset "+2.25mm" (2)
#367320 Rear Arm Pivot Pin (2)
Fits: XB2'18 Carpet.
#5532
Some new goodies... I really like the motor plate.
New Exotek XB4 alloy hubs, carbon fiber battery strap, and XB2 motor plate :: LiveRC.com - R/C Car News, Pictures, Videos, and More
#5533
I’m thinking about ordering this or the Schumacher KC.
Have you ran them both?
It looks like amain carries more parts for the xb2 but I haven’t searched too hard yet.
I’m sure either car will out perform me lol
#5534
I would think you will get mostly biased opinions here for a reason. Schumacher makes a more than capable car but are very fragile. Parts are not easy to get even for team drivers. If you are only running on carpet and dont hit anything or no one ever hits you it might be the car for you.
#5535
finishing the race is important lol
