Xray XB2 2WD Buggy Thread
#5356
Let me know if they even answer. My kit was missing the battery foam (of all things!!!). Despite my emailing them several times, I have yet to hear from them. "Luxury" RC car my foot. Things have gone down hill for Xray over the years and support is not what it used to be.
#5357
t-bone racing does. They make bumpers and such for xb2. I actually use the bumpers for my kids. They are fantastic. I am sure the shocktower guards are just as good.
#5358
Hey what is the correct driveshaft length.
#5359
I have a few setup questions. In the manual it shows two alternatives.
1. having the the gears on the left side
2. mounting the shocks on the back of the tower.
What benefit do these provide, or I should say what does this change?
#5360
The manual for the XB2 '17 dirt edition indicates that the initial pill setting for RF and RR are in the center and produces 4 degrees of toe in. The downloadable basic setup sheet for this kit has the same pill settings and the sheet indicates 3 degrees of toe in. Am I correct to assume the set up sheet has an error and the manual is correct with 4 degrees of toe in with these pill settings?
#5361
Has anyone experimented with shimming the transmission case on the XB2 1 or 2mm? I have seen some setups on other cars with the transmission case shimmed and some setups for the XB2.
#5363
I have done a lot of reading and I think I understand that the "left side gear" is the 4 gear laydown setup. Not sure what benefit that would give me.
Next Question, people at my carpet track are using 3 dot springs front and rear. I bought a used car that came with a bunch of springs, one pair is a rear two stripe progressive. I do not see any setup sheets where someone is using two stripe. What is a good application for these? Is there an associated or Losi equivalent to the three dot? I have three dot for fronts.
Last question for now. I have stock shock oil in my car. I asked another group what shock set up they had. They were all using 35 wt. I do not see any X-ray/Hudy 35 weight shock oil. This is probably some other company. I looked for conversion chart and could not find one. Is there a 35wt Hudy shock oil?
Thank you
Thank you
#5364
Thank you
Thank you
#5365
We only mount our shocks on the rear for loose dirt.. moved to the front for high bite clay..
you are correct on the transmission setup.. the original 16 car had a 4 gear laydown or option 4 gear dirt standup.. which had the spur on the opposite side of the car from the current car.. it also rotated the opposite direction.. since the 17, and 18.. 3 gear laydown..
Oils have a conversion... most use the CST rating now.. i have a chart for that.. here it is.. this is the AE conversion chart.. losi oils are different..
10wt = 100cst
15wt = 150cst
20wt = 200cst
22.5wt = 238cst
25wt = 275cst
27.5wt = 313cst
30wt = 350cst
32.5wt = 388cst
35wt = 425cst
37.5wt = 463cst
40wt = 500cst
42.5wt = 538cst
45wt = 575cst
47.5wt = 613cst
50wt = 650cst
55wt = 725cst
60wt = 800cst
70wt = 900cst
80wt = 1000cst
10wt = 100cst
15wt = 150cst
20wt = 200cst
22.5wt = 238cst
25wt = 275cst
27.5wt = 313cst
30wt = 350cst
32.5wt = 388cst
35wt = 425cst
37.5wt = 463cst
40wt = 500cst
42.5wt = 538cst
45wt = 575cst
47.5wt = 613cst
50wt = 650cst
55wt = 725cst
60wt = 800cst
70wt = 900cst
80wt = 1000cst
#5366
Thank you
Thank you
Xray 3dot is 4.11 rate. the closes AE spring is orange which is 4.05. to use AE springs.. you need to flip the threaded shock collar.. also use AE lower spring retainers..
here is what i have.. hope it works right.
Part # Color Rate
Front
Avid AV1201-WHT White 2.63
AE 91341 Brown 2.85
Avid AV1201-YEL Yellow 2.95
AE 91341 Black 3.00
AE 91341 Green 3.15
AE 91342 White 3.30
Avid AV1201-RED Red 3.33
Xray 368183 1dot 3.3-3.35
AE 91342 Gray 3.45
AE 91342 Blue 3.60
Avid AV1201-PUR Purple 3.62
Yok Yat YAS-825 Yellow 3.68
Xray 368184 2dot 3.71
AE 91343 Yellow 3.75
Yok Yat YAS-800 Red 3.83
AE 91343 Red 3.90
AE 91343 Orange 4.05
Xray 368185 3dot 4.11
Xray 368186 4dot 4.57
Yok Yat YAS-700 Orange 4.60
Yok Yat YAS-675 Black 4.84
Yok Yat YAS-650 Purple 5.11
Xray 368174 2stripe 3.71-4.85
Rear
AE 91344 Black 1.90
Avid AV1200-WHT White 1.94
AE 91344 Green 2.00
Xray 368284 1dot 2.00
Avid AV1200-YEL Yellow 2.10
AE 91344 White 2.10
AE 91345 Gray 2.20
Avid AV1200-RED Red 2.24
Xray 368285 2dot 2.28
AE 91345 Blue 2.30
AE 91345 Yellow 2.40
Xray 368286 3dot 2.57
Yok Yat YAS-1050 Green 2.71
Yok Yat YAS-1025 Orange 2.76
Xray 368287 4dot 2.86
Yok Yat YAS-1000 Black 2.87
Yok Yat YAS-975 Purple 2.97
Xray 368273 2stripe 2.00-2.57
#5367
What about the progressive springs. When do you use those?
#5369
Does it make sense to use the slipper eliminator with the dirt version? I plan on running it 17.5t.
I have not seen that setup in any pic.
