Schumacher's new K2 4wd buggy ..!
#827
do you think new 4wd buggy coming out soon ??
#828
Looks awesome!
#831
What are you guys running for gearing with 13.5
#832
Hi guys. Can anyone tell me what effect the wide rear pivot has on the K2, other than what's in the release notes from Schumacher? I think I have found on cold wet bumpy astro that that it makes the rear of the car less predictable and snappy. Thanks
#834
The trouble is all other manufacturers that also use 13mm bore shocks now use a washer and screw for mounting their pistons rather than the Schumacher e clip mounting which is why AE and Tekno do not fit. The only way would be if you could change the shock shaft as well if it was the correct diameter and length and that the screw does not hit the inside of the cap. Schumacher smallest pistons come with 1.5mm hole and then you can drill these to larger sizes but apart from TMG I cannot find anyone else making pistons with smaller holes that fit.
#839
May worth to try, to glue the existing holes with super glue, after cleaning them with break cleaner, and drill new holes in the size you like.
I‘ve heared also, that someone was gluing the tip of a tooth stick into the existing holes, too.
#840
Is there interest in both the small and big bore blanks ? one or the other ? We've considered having these made but struggled to gauge interest ... We could have them done relatively easy if there are enough wanting them ..
..p
..p
