Team Associated's new RC8B3e
#1306
Alegidly mugen arms fit.
#1307
Well im afraid to turn the thermal protection off because i know its overheating because it will melt your skin on your finger if you hold it on there lol i have an smc 1900 i just want the hobbywing stuff to work. Ill call up hw i guess and put in my backup smc 1900 thanks guys
#1308
Once you over heat a motor really good for what ever reason, I mean cook it, you detroy the coating on the windings and they will always run hot and eventually thermal. Hate to say it but you may have a practice motor as they will run fine for 5 to 7 minutes but the temps will continuously keep creeping up. Open it up if the windings on the stator are discolored (they will look blue/grey kinda like a black and blue on your arm).
#1309
#1310
A friend had a HW Shortcourse motor that ran really hot. Put his old HW motor in and problem solved. If it is the speedo. That is another thing
#1311
Just built a new B3e with a M2C chassis. Chassis seems to be 2mm to long. When its flexs my rear universal falls out. Anyone have or have seen this issue?? (I also have a b3 m2c chassis,it measures same as my stock b3e)
#1312
#1313
B3e
the m2c chassis was ordered for the b3e and is stamped M2C B3E as well. But.......hahah
#1314
I guess talk to M2C racing about the chassis. Also maybe you can install the new 17mm outdrives into the center diff which is +2mm longer.
#1315
Been trying to contact M2C But no response so far but only been a few days. But unfortunately we are leaving in a week for GA(10 HR DRIVE) Guess stock chassis will have to work. Didnt know new outdrives were longer, that could work for sure, thanks for the help!
#1316
15mm and 17mm outdrives
hi,
pls tell me which outdrives come to front and rear diffs and which to center diff?
Manual says 15mm outdrives for front and rear diffs and 17mm to center diff.
But... I have in kit included 17mm outdrives 4pcs and 15mm outdrives just 2pcs
So question is - is it a mistake at manual or I have wrong quantity of each outdrives included at kit?
#1317
hi,
Illustration at the bottom of page 5 shows front and rear... 17 and 15
#1318
Yes, we are driving down for the Wicked Weeekend. Thanks for the info, ill see if he is there and what he says! Thanks
