Team Associated's new RC8B3e >
Like Tree103Likes
Old 07-29-2017, 01:34 PM
  #1291
Originally Posted by josh short
will the rc8b3.1 diffs fit in rc8b3???
Yes they will
190mph is offline
Old 07-29-2017, 05:25 PM
  #1292
Has anybody tried the lower front/rear arm anti twist bushings? I know PSM makes them and possibly revolution designs. I was looking into them for my T3, thanks for any input
racingnewb is offline
Old 07-30-2017, 01:24 AM
  #1293
I've run them and they didn't seem to make a huge difference. They did cause a bit of binding in the arms but a reamer could fix that.
KCodd is offline
Old 07-30-2017, 05:29 PM
  #1294
iroczcec's Avatar
Trader Rating: 140 (100%+)
does anyone have any tips to tighten the rear up on my rc8b3e I am running on a big outdoor track with low grip I have a black sway bar on the front blue on the back 7/7/3 diff 37.5 in the front shock 32.5 rear ride height 27 front and rear but when I go around a turn and get into the throttle it want to keep going around I have cvd and v2 diffs yellow springs on the front and either green or blue on the rear any help would be appreciated thanks
iroczcec is offline
Old 07-30-2017, 05:36 PM
  #1295
PorTX's Avatar
This may not be the way everyone does it. But I would, try more rear toe in, first. Then up the rear diff oil if you need more.
PorTX is offline
Old 07-30-2017, 05:40 PM
  #1296
ravage's Avatar
Trader Rating: 15 (100%+)
I am using 50 in the front 45 in the rear, white shocks all the way around I have my ride height at 27 as well I have my rear camber link the 2 hole as of right now, i might move it up to the 3.
ravage is offline
Old 07-30-2017, 05:43 PM
  #1297
5k in rear diff, move rear camber link next, shortest wheelbase in the rear.
Old 08-01-2017, 09:36 AM
  #1298
Anyone running the hobbywing xr8 motor and esc? My motor overheats like crazy.. I've tried different pinions from 14t to 17t but nothing helped. I have a 15t on it now. Motor spins free and so does the drivetrain. Bearings are good, solder is good(even re soldered and shortened the wires). Its overheating so bad i can maybe go 9 minutes if i dont have a heatsink and fan on it and even with the hs and fan it will thermal at around 14 minutes so thats cutting it close in an a main with practice laps. If anyone has any input.. thanks
Cday is offline
Old 08-01-2017, 10:50 AM
  #1299
Which motor? 1900 or 2250?
KCodd is offline
Old 08-01-2017, 10:52 AM
  #1300
Does the drivetrain spin freely when you have no pinion? What are your diff fluids?
KCodd is offline
Old 08-01-2017, 11:06 AM
  #1301
Its the newest 1900kv and yes its free when the pinion is off. Running 5/5/3 in diffs. Esc doesnt get very hot its just the motor and its about a month and a half old. I also drilled holes in the body for air flow and it didnt really change anything.
Cday is offline
Old 08-01-2017, 11:11 AM
  #1302
Call them up because it needs to go in. I just lost a tekin ESC so don't feel bad. Look into SMC 1900. They're $70 and really good motors.
KCodd is offline
Old 08-01-2017, 11:37 AM
  #1303
Trader Rating: 21 (100%+)
Do you have the thermal shutdown enabled in the esc, or are you checking the motor temp directly with an IR thermometer? I have found the Hobbywing thermal protection shuts off WAY before the motor is actually too hot. I always disable it and measure the motor temps.
MX304 is offline
Old 08-01-2017, 12:46 PM
  #1304
Well im afraid to turn the thermal protection off because i know its overheating because it will melt your skin on your finger if you hold it on there lol i have an smc 1900 i just want the hobbywing stuff to work. Ill call up hw i guess and put in my backup smc 1900 thanks guys
Cday is offline
Old 08-01-2017, 01:05 PM
  #1305
Default front arms
does other brand lowewr front arms fit instead of original B3.1 arms?
need to go to race with new just built kit with no spare front arms, as those are out of stock, so curious if some other brand front arms could fit...if some need ocurs.
hardijs is offline
