Tekno RC EB48.3 Thread
#2101
What weights should I start with?
#2102
Well when I build the diffs for the first time I wasn't sure whats a good way to start. I have 10k, 7k, 5k, 3k laying around. and various shock oils. I was mostly concerned with diff oils though for the first build. I see in the manual it says 555, but most setup sheets I see 995, or 775.
#2104
#2105
Thanks! I'll definitely start around that, instead of stock... No point immediately checking the diff oil after building it.
#2107
#2108
Anyone know how mugen diff fluid compares to PT, I used mugen 7k in the front/center and 5k kit fluid in rear. I am in process of changing everything to pt but probably won't get to before the weekend
#2110
#2111
anyone ever bent the main driveshaft ?
#2112
#2114
I've been running tekno for almost 2 years, and crash rather spectacularly at times, and have yet to bend a driveshaft. I have had my truggy flex enough to have my rear driveshaft pop out though.
#2115
There's probably a good half inch of play front to rear in the front driveshaft. I actually feel it's too much. How much more do you want to allow for bad landings? Not sure I would call that a weak point of the car. Although I did see a picture of a severely bent driveshaft on FB, but couldn't imagine how the heck the guy pulled that off.
