Team Associated SC5M Thread >
Like Tree84Likes
    Hide Wikipost
Old 04-02-2017, 11:22 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated SC5M Thread
Last edit by: Wildcat1971
Team Associated SC5M Wiki Content.
Print Wikipost
Old 02-28-2016, 08:16 PM
  #1411
cbass722's Avatar
Default ??
I finally put the brass c plate on the back, but I'm still running the plastic do plate. Is it worth upgrading the d plate
cbass722 is offline
Old 03-02-2016, 03:11 PM
  #1412
TravisS27's Avatar
Trader Rating: 31 (100%+)
What are your shock setups for stock sct? Oil, springs, pistons, ride height....
TravisS27 is offline
Old 03-02-2016, 03:12 PM
  #1413
TravisS27's Avatar
I run plastic C and D mount on mine...but I'm running stock class and looking for the lightest overall weight
Old 03-05-2016, 12:36 PM
  #1414
Default Servo
Anyone using the Futaba s9551 servo? I have a spare from my oval cars. Was wondering if it will work/last in the SC5m? Or if I am better off buying something else?
Lvxlr8n is offline
Old 03-08-2016, 11:25 AM
  #1415
I've used that servo in buggies, but the torque might be a bit on the weak side for the larger truck tires (122 oz-in @ 6.0V).
I like to run a stronger servo in SCT because sometimes you can use your steering throw to get out of wrecks / break loose from a pipe during a race.
WRXnItUp is offline
Old 03-08-2016, 08:42 PM
  #1416
Originally Posted by QDRHRSE
The SC5M is lighter than the other MM trucks. IT wouldn't take much to get it to the legal weight minimum. Mine is relatively close with a short pack and it must be close to box weight. Sure I have ti turnbuckles and screws, slipper eliminator, and a CF strap....I also have a brass C mount and MIP 3 gear.
I noticed you mentioned the slipper eliminator. Are you running yours in a stock class? I was told not to run the eliminator in my 2wd mod buggy but, I put it in my ST and am very happy with that setup.
freezeframe007 is offline
Old 03-11-2016, 09:03 AM
  #1417
Default Picking up a sc5m used
I am picking up a sc5m next week (2 race used roller). I plan on using it for 2wd mod class. It was never run without a chassis protector and only used for two race days. I already has some of the upgrades that I have read about over the last 95 pages:
3 gear tranny
Al rear hubs
Light weight gears
Ceramic ball/diff
Ti turnbuckles
Not sure about brass weights/parts...
Not sure about shock springs...
My local track is usually low-medium traction dirt/clay composition. Some times (like right now), we get a good groove built up and traction is pretty good in the groove. I have both shorties and square packs to try out and see which work best.
From what I am reading; these are some of the other things I need to look for on the buy or do myself afterwards:
Grey front trucks springs... Are there any other parts needed for this mod other than the springs?
Front shock oil @ 37.5...maybe 40
Rear shock oil @ 32.5
White springs in rear
Brass C plate
6mm and 8.5mm hexes... Do I need different axles to make this modification?
Am I overlooking anything else?
Thanks in advance
Patt
Old 03-11-2016, 09:17 AM
  #1418
Trader Rating: 515 (100%+)
Yes. Anytime I run stock I use a slipper eliminator. Its probably the best bang for your buck mod that you can make. I run it in all my 2wd cars. The Schelle slipper is good too but unless your on ice you're going to pretty much lock your slipper anyway with a 17.5.
If you're on lower grip surfaces the 4 gear trans is a great tuning tool. I run one during the winter when its cold and we run our track wet.
QDRHRSE is offline
Old 03-11-2016, 01:21 PM
  #1419
celt's Avatar
Antelope Valley, CA?
cold?
What?
celt is offline
Old 03-11-2016, 05:14 PM
  #1420
Just figured I'd throw in my .50 opinion here after reading a bunch of these posts.
Guys.....Girls.....this truck is fast. Straight out of the box fast. No blue parts are needed for this truck to set new personal best lap times. I started with the kit set up- 100%. I then proceeded to best my best SC10 lap time by almost a second. Seriously. I noticed and felt that the inside front tire was compressing too much on high speed corner exits so I installed the Grey truck springs in the front. It didn't get faster but it was easier to drive. Some of these part lists are crazy. You don't need any of it to drive this thing to the front. For some of you guys that just bought it, put it together right, then try driving it. I was blown away by how good this thing is. Running multiple classes is easier too. Transitioning from my 5M to my T5 to this is seamless.
No harm no foul I was just getting the impression that some of you were thinking you needed those lists to be competitive with this truck. You don't. Spend your initial money on wheels and tires. Carry on. AR
Alan_r is offline
Old 03-11-2016, 05:37 PM
  #1421
3 gear tranny
Al rear hubs
Light weight gears
Ceramic ball/diff
Ti turnbuckles
Brass C plate
Thanks in advance
Patt
Just make sure you go through the truck. I bought mine used and found some disturbing discrepancies in the build. There were loose spacers and c clips in the shocks and the diff was built with black grease instead of the silicone diff lube.
I have to say that I am having way more fun with this truck than I ever expected.
afm223 is offline
Old 03-11-2016, 05:49 PM
  #1422
"I bought mine used and found some disturbing discrepancies in the build."
That's always awesome isn't it? I buy, build and pass on lot's of Ebay rollers and wrecks....the stories....ha!
One thing I've noticed with my S5 is that the ball diff requires more attention than my other 5M vehicles. Maybe it's just mine but after about 3 batteries I start to notice a change in the corners. So I bring it in and every time the diff needs to be tightened and then loosened again 1/8. I think it's a fluke so this truck may just get a BFAST rebuild. Who knows, maybe I messed something up scuffing the rings at 4am one night.....
Alan_r is offline
Old 03-11-2016, 06:11 PM
  #1423
cold?
What?
High desert 60 miles north of LA. We have 4 seasons. Freezing winters and 100 degree fall temps. Its nuts. We've seen temp changes of 50 degrees in a day!
QDRHRSE is offline
Old 03-15-2016, 04:41 AM
  #1424
kvrc's Avatar
Anyone running the Light .030 bodies? I'm looking for opinions on how they are holding up compared to a standard thickness body.
kvrc is offline
Old 03-15-2016, 05:28 AM
  #1425
celt's Avatar
Default slipper eliminator
Gents,
Looking to try a slipper eliminator with the SC5m, but concerned about the increased load on differential gears. A 2WD buggy concerns me less with it's smaller wheels and lighter weight.
Any comments on problems or success?
celt is offline
