Rapture 2.0 4x4 SCT by CRP
#271
If I go ahead and pull the trigger, any extras I need?
#272
I will tell you this is the best 4x4 truck on the market...but I am a tad bit bias since it is my and Chris Krio's baby.
So for spares, I would say one wheel cvd shaft, cvd barrels, front upper and lower arms, and a set of front knuckles. You probably won't need any of these spares. The truck has no weak issues. Hope this helps, and I hope you pull the trigger!!!
#273
The truck was originally designed for low-bite and bumpy indoor tracks we have in Michigan. I never knew it would be even better on high bite. The 2.0 changes the suspension to dominate outdoor 1/8th tracks as well as small technical indoor tracks. So the 2.0 is more of a dual purpose truck, where the 1.0 was better suited for only indoor, but held its own outdoor.
Rapture durability is class leading. Tekno is a 8th scale design also but made everything plastic, where we kept aluminum and carbon fiber in the places it needs to be. I have raced this thing since the summer of 2012 and I have broke 2 knuckles racing in sub zero weather. I am still using the original diff gears. I changed the bearings once when they felt gritty last year. That's all that broke on me, and I do hit the tubes a lot :-P
#274
The Rapture 2.0 kit comes with a single battery tray to run a 7.4v stick pack, The 2 1s or 2 shorty pack setup is a option part..
#275
2.0 looks like this..
#277
#278
Here is a video of my Rapture 2.0 running on a indoor high bit clay track..
https://www.youtube.com/watch?v=Hkf7uTE_vXE
#279
I just received my new extreme 5800mah 100c batteries from SMC.. 8 grams lighter then my older 7200mah batts..
#280
#281
Yeah the weight loss takes our truck to another level... Gets the truck down to around 6.7lbs and the rear traction with the ninja tray is insane!
#283
#284
#285
