Team Durango DEX8T
#391
Tech Legend
cool got pics?
I got some stuff I sold so now I can sit down and look over my vehicles more.
I am thinking of getting some more basher friendly electronics, by that I mean waterproof, for at my 1/8s. With Viper effectively not having a 1/8 ESC now, not exactly much choices. So may give the newer Mamba a look that cna do sensored operation now.
Don't get me wrong, the tekins work fine, just wish they were waterproof.
Anyone got any news on what they have found for setup using Tekno springs?
#392
#393
Tech Legend
check out my set up sheet "in the pits" on TD's site.
how would you say that setup on the shocks would be for loose conditions.
or, maybe a better question, which of the tekno springs you feel best match the performance of the stock springs. And if its not a direct match what do you recommend changing shock wise (say go up 5W oil with X Tekno spring to get some feel as stock shocks, etc)
#394
thanks.
The "pink" tekno springs are VERY close to the stock spring rate, they are just longer so that you can get the proper ride height and have a little adjustability.
#396
Any news from team Durango about longer springs. I have the talion with dex8t shock towers and front hinge pin holder
#398
Which ones would be the best
#400
Didn't work. Team Durango is sending me tekno 90 mm green and yellow for free. Very happy with this company
#403
Link did not work
#404
I finished installing the electronics on the truggy I just got. Tekin rx8 and a t8 2250. Question is, does the reedy 4600 4s 55C I've been running on my buggy hold up on the truggy?
#405
Tech Legend
I'd suggest going with a 6500mah or larger battery personally. Your battery will probably hold up, but if your needed runtime is anything like what I needed (10 minute mains), you may find you would just be scraping by.
Or, you coudl run with doing a "lite" truggy. that is, lighter battery, buggy sized motor, and that battery. I'd bet it would be pretty nimble.
