Tekno RC SCT410.3 Thread
#5776
A friend and I were discussing this at the track today. My 410.3 is pretty beat and I think I'd rather just get a new kit. He said i should just wait for the new version. Just not sure when that is coming.
#5777
Hi guys just bought tekno sct and want to go to the local race, now in winter my offroad race club moved too indoor carpet track without any bumps, so we are doing touring with schort courses, tires allowed only slicks, what kind of setup are you suggesting for my sct?
#5778
Got these coming...
Nice little upgrade.
https://www.teknorc.com/shop/tkr8727...uires-tkr8730/
https://www.teknorc.com/shop/tkr8730...uires-tkr8727/
#5779
My personal opinion is that race quality SCT 4x4 is not a big enough market for them to spend more resources on (just like EB SL), so unlikely they will put out anything soon. The fact that Associated doesn't even bother selling a truck kind of tells you the state of SCT 4x4 world-wide. I'm sure there are pockets here and there where it's still big, but overall market is probably declining.
#5781
Edit: Posted a dumb question and deleted it.
#5782
I took some measurements while I swapped out my motor. The 17 tooth pinion is 10mm from the motor shaft to the tip of the teeth. The max I could go with the motor slid to the end of the slot was 15mm. So that tells you what the max size of your pinion gear. A quick calculation using 15/10 x 17 gives a 25 tooth pinion. Not sure one that big is available but theoretically it would fit. A 21 tooth should fit with room to spare.
#5783
#5784
Most of us have seen this document, but for those who haven't, it's an invaluable resource and well done.
https://www.teknoforums.com/misc/Tek...etup-Guide.pdf
Download it, print it, read it, and put it in your bit box.
#5785
#5786
#5787
I recently finished building my .3. I have a savox 1258tg, srs6000 reciever, HobbyWing sct pro esc and Tekin Pro 4hd. I’m have trouble with truck turning sharp in both directions on its own after accelerating, at all speeds. Do I need an external bec or glitch buster to fix this problem?? Not a total noob with rc but just getting back into it.
#5788
#5789
im using a 1258tg on my eb48.3 and it works fine.
