Tekno RC SCT410.3 Thread
#5761
#5762
Proline EVO
I really like the Proline EVO body. It's been one of the most rugged bodies that's held up.
#5763
I've used Speedline Plus SC, no issues. Really solid wheels.
#5764
#5765
I've battled with the setup for a while, but for now settled on pink front (LF) and green rears (LF) for now with 35 f and 30 rear TLR oil. For a super rough blown out track it seems to work pretty good as long as I run the ride height up a ways. I have every spring tekno has made for the truck and am still experimenting with shock packages though..
#5766
I installed my AKA Typos on these wheels and was not happy with how the larger diameter side of the tire fit the wheel. Its not snug and there is a gap I cant close in some areas. They were not easy to get on. Did I stretch the tires causing this?
#5767
I've never used AKA short course tires, but I've used a lot of the DE wheels and it seems that sometimes I have the same problem where the wheel needs to be maybe 1/8" bigger diameter in order for the tire to fit properly. I just put a lot of glue in the channel where the bead sits, then put the tire in then tightly wrap electrical tape around the edge of the tread for several wraps, forcing the bead to go in nice and tight. Seems to work good for me that way...
#5768
#5769
Has anyone replaced drive pins in the driveshafts before? I've got no problem pressing them out, but can't seem to find replacement pins being sold anywhere.
#5770
#5772
#5774
i glue the smaller side first had good luck turning the tire inside out and then loading up the outer wheel channel with glue then quickly feeding the tire into the bead and spinning the tire a little before the glue sets. this has to be done quickly but i have found the best way to get the bead seated well. then after that sits for a while put the foam on and roll the tire over it. then make sure the foam and back side bead are matched up. it requires a little massaging of the foam and if you push it a little towards the bead the tire will sit in their nicely ready for glue.
#5775
Just thinking about buying a new unit ...should I wait for the next release or is this it ? Thanks
