RC Shock Dyno Test Results >
Like Tree17Likes
Old 03-16-2015 | 09:49 PM
  #61
Riv2SC10's Avatar
From: In the Greater Ladysmith, WI metropolitan area
I've been doing some more figgerin'. Ray Munday has posted a damping comparison for several 12mm and 10mm pistons in his thread in the Aussie section. The graph shows the damping force for the different pistons with varying viscosities at two different piston speeds (50mm/s and 2000 mm/s). Obviously that's just a short step away from calulating the damping coefficient (N/mm/s, or N-s/mm), and for the same piston and oil, the results are much different between the two speeds. This appears to indicate that the damping coefficient of the shock is not linear with speed. Hopefully, Scott is able to generate some data at higher speeds to confirm or deny this. I believe the graph Ray has posted is based on calculations rather than actual dyno data, but I guess I'm not sure (maybe he can chime in on that).
Plus, when looking at Scott's F-V graphs, there appears to be a bit of non-linearity (exponential???) displayed on the rebound (downstroke) of the shock, particularly in the Viscosity Effects graph. Perhaps that would also be showing up on the upstroke (compression) side as well if it weren't for the "spring affect" from the air in the oil. The lines are much cleaner on the down stroke, and you can see some non-linearity on that side.
The flip side is that this non-linearity doesn't show up as much in other comparison data Scott has presented (Emulsion vs Bladder, etc.). In fact, the Bladder and Foam graph appears to be very linear. So maybe there isn't anything to my interpretation of the graphs. I'm curious, though, to see how this shakes out if Scott is able to generate some higher piston speed data. The data provided by Ray appears to show non-linearity of damping coefficient with speed, and based on simple flow through orifice type calculations and whatnot, there should be some sort of exponential component to the damping with increasing to piston speed. But maybe at this scale the typical orifice flow models are no good??? I'd believe Scotts dyno data over a calculation, personally. It's hard to argue with good data, but easy to overlook something when creating a calculation.
Thoughts?
Riv2SC10 is offline
Old 03-16-2015 | 10:42 PM
  #62
Kyosho makes 12mm blank pistons.
Eric Tomczyk is offline
Old 03-17-2015 | 09:58 PM
  #63
icecyc1's Avatar
Ray Munday's plot is a calculation plot, not dyno data. With that said, it's not too bad from a relative perspective. It definitely shows the relation between your piston options and viscosity and how they can affect low speed or impact damping. I think it would be better if Ray speaks for his plot himself, but I think it is a well designed plot. Maybe he'd like to recreate that plot with actual data at some point?? :-) As with any calculations, many assumptions and simplifications usually need to be made, but it doesn't mean they are wrong. As I like to say, a model or test should only be as complex as it needs to be to give you the information you need in order for you to make the "correct" decision.
I have just made an impact tester, so I'm starting to get some higher velocity data. I'll say it doesn't look quite like I was expecting, but I think it can be justified. I need to review it more before I publish it. There is a lot of interesting little details that can be seen in the plots that a more experienced eye than mine can see (thanks ray). I'm still learning, but I hope to pass along those details as well. I think a lot of folks will be interested in what goes on inside their shocks, there seems to be a lot more than what initially meets the eye.
My next major publication will be a piston hole and number study at all three velocity levels. It will definitely take me a few weeks to gather, analyze and report that data, but it will be coming. I'm just as excited to see this data as you all are.
icecyc1 is offline
Old 03-30-2015 | 12:32 AM
  #64
ray_munday's Avatar
Hi guys,
sorry for being absent - had a business trip to Japan, major race meet and a chest infection thrown in to the last 3 weeks!
The sheet was a calculation based on empirical data of flow through real (ie not zero length) orifices from laminar to turbelent ranges. Our pistons and typical speeds fit within the range of conditions used to create the empirical model, so I believe it is mostly valid, however as I mention on the sheet it does not include the effect of fluid aeration (which can affect viscosity and oil compressibility) which is obviously critical in an emulsion shock.
The calculations can be shown as a F-V curve, and ideally for correlation of the model we would overlay that with Scotts data for a few different piston / oil types. The non linearities are far more evident at higher velocities, so until the tests are done at these higher speeds its hard to fully correlate the model. Once that is done, we will overlay the results on my original graph and see if it was worth the time and effort it took to find the research paper and create the sheet
Scott and I have exchanged several emails and he has been kind enough to share the raw data with me and there is a lot of additional data contained there which we are beginning to fully understand and be able to explain. As always data throws up more questions than answers in the beginning.
As for damping coefficient - some care needs to be taken when calculating the 'ideal' coefficient for a vehicle suspension. Most text books talk about a single degree of freedom (1DOF) model (1 mass, 1 spring, 1 damper) and for this case its easy. But cars have several degrees of freedom - there is the mass of the suspension (unsprung) and the mass of the chassis (sprung) as well as the coilover unit and the tyre (which is actually a spring / damper). There is a different ideal damping ratio for the sprung mass and unsprung mass, not to mention pitch and roll modes. As an example, if you keep increasing damping with a 1 DOF system, it will become more and more damped. However with a car, if you make the damper too stiff, you reach a point where the suspension stops working and the tyre becomes the majority of the suspension - and as the tyre is relatively undamped, the car as a system will have less damping (this is a big issue in F1 cars). There is a balance and it heavily depends on the tyre / insert performance.
Sorry for the long response.
Ray
Thoughts?
ray_munday is offline
Old 04-28-2015 | 09:48 PM
  #65
icecyc1's Avatar
Default New data for specialty pistons
I have just posted some results for specialty pistons (tapered, tapered holes, engineered, valved, split piston). The results are general to show you what the curves look like with each type of piston. It should give you a much better idea about what is changing as compared to the standard flat piston (linear Force-Velocity curve). The results are interesting. Some are expected, some are not.
Overall, this is intended to be informational, and is not going to tell you directly which pistons you should or should not buy. That will still be up to you to decide. Many people claim to have benefits, or don't see any benefits to using each of these types of pistons. Maybe now you can see for yourself why you like or don't like some pistons.
High level conclusion: Most of the piston types do SOMETHING. They may or may not do what they are advertised to be doing. If you can take advantage of the piston's characteristics, you can probably make any of them work for you under the right conditions.
https://drive.google.com/file/d/0B-9...SE0/view?pli=1
cheers
icecyc1 is offline
Old 04-29-2015 | 07:20 AM
  #66
Thank you, I really dig this stuff
30Tooth is offline
Old 04-29-2015 | 09:50 AM
  #67
How about a look at 2 stage pistons like those Mantisworx offers on RCSHOX? May as well throw his trifex pistons into the mix as well.
s1a1om is offline
Old 04-29-2015 | 10:02 AM
  #68
RC10Nick's Avatar
He did...
RC10Nick is offline
Old 04-30-2015 | 07:48 PM
  #69
ray_munday's Avatar
Awesome stuff Scott! Been a pleasure to help out with some of the interpretation and looking forward to the next round of testing
Ray
cheers
Old 04-30-2015 | 09:23 PM
  #70
icecyc1's Avatar
I definitely appreciate the help with interpretation Ray.
To me, and likely to most of the readers, the most difficult part of all this data is translating what these curves mean for your car's handling. I can show plots and curves all day, but if they can't be understood to use that data to affect your car, it's all worthless. I'll admit, so far, this data is fairly technical, and may not have too much real meaning to all but the most technically savvy people. The real value will come when most or all drivers can understand what they need to make their car handle better. My ultimate goal (the FINAL report) is to publish a shock setup guide that removes as much of they mystery and guesswork out of all the changes you can make, so you can more efficiently get to the best shock configuration in any given situation. It will never tell you the exact answer, and it would be foolish to think that way because every situation is unique. This is definitely not easy, and will certainly require some real world feedback from racers.
I've mentioned upcoming tests before (but have been sidetracked a few times). Here is my list again for the near future:
1. More detailed effects of bladders and rebound
2. Impact testing (Pack)
3. Variations of # of holes and hole diameter (for the basic flat piston)
4. Shock Fade due to Temperature rise rate and emulsion
5. Actual in-situ shock velocity measurements on a car
I'm taking notes from people's comments about what they'd like to see, and I really appreciate the feedback. I'll do my best to address those requests, just no guarantee on the timeline or the ability to measure, but I'd enjoy the challenges.
cheers
icecyc1 is offline
Old 05-01-2015 | 12:22 PM
  #71
Thank you icecyc1, I've added damping graph to my spreadsheet so one can see if the suspension bottoms out for a given height drop or if oil is too stiff/too soft provided the damping coefficient.
Cheers.
30Tooth is offline
Old 05-12-2015 | 03:04 PM
  #72
shannow's Avatar
Thank you again for all your work !
I have a silly question... which one is better between a higher compression damping effect than rebound and the opposite ? In other words should I always have the flat side up ?
Edit: Presumably flat side up is the way to go after a brief research. Funny I always fought that strong compression and fast rebound was better to keep the wheel on the ground but it seems more complex than this.
shannow is offline
Old 05-12-2015 | 05:30 PM
  #73
thecman26's Avatar
R/C Tech Elite Member
Dang... I spent $14 on AE 3X1.4 tapered pistons and theres not any difference between them and the stock pistons?
thecman26 is offline
Old 05-12-2015 | 06:23 PM
  #74
Default Big Thank you
I just want to say big thank your time to put together this document plus everyone input.
I am just getting into shock, pistons oil, springs ect. Last night had my first race in almost 20 years !
Thank you !
Dmitri Tech is offline
Old 05-13-2015 | 04:47 PM
  #75
icecyc1's Avatar
I don't think you can say which is better... higher compression or higher rebound... It all depends on the situation. From what I've read and understand, full scale off-road like motocross or snow cross typically run an FV that has lower high speed (less pack), and a lower rebound for better launching over jumps. But then again, you might find riders running a little higher rebound to feel a little more planted. It all comes down to personal preference. I'd say experiment with both directions of piston and see what you think works better. By changing viscosity, you can keep either the compression or the rebound the same, and increase/decrease the other end.
I wouldn't yet say you wasted your money. I will say that in LOW VELOCITY (pitch and roll of car), the taper will have little to no effect. I have not yet tested impact (jumps), and there could be a difference in the pack qualities. That's the main thing I really need to test, I think people want/need to know that. (by the way, I've also spent my own money on all these pistons I've tested myself.... all for the sake of testing
Thank you !
Me too... I did this for a few years as a kid, had a couple RC10's. Just got back into it for the engineering marvel, and I'm trying to understand it. That's why I built the dyno. Might as well share the knowledge instead of keeping it to myself. Thanks.
icecyc1 is offline
