Like Tree104Likes
Yokomo YZ-4
Old 12-11-2015, 10:22 AM
  #526
joeymdz's Avatar
Originally Posted by John Myall
I ran the 22-4 last year, almost put me off racing! To be fair to it, it was nice to drive, just isn't suited to the high grip tracks we have in the UK, it struggles to get the last half a second a lap out of it.
The YZ4, it's early days, I've only been to two meetings so far, but am loving it. Seems to drive somewhere between my '13 spec XB4 that I ditched the 22-4 to go back to & the Durango 410 I ran before that, which is probably the best car I've had.
mines 1666
has an orca shorty, orion r10.1 with fan, and aluminium bits
joeymdz is offline
Old 12-11-2015, 01:02 PM
  #527
Originally Posted by joeymdz
mines 1666
You must have put a micron less paint on the bodyshell than me. I'm all but a gram the same.
Piles is offline
Old 12-11-2015, 01:12 PM
  #528
joeymdz's Avatar
^^HAHA.... I used Speed WHITE to achieve weight loss
joeymdz is offline
Old 12-11-2015, 01:46 PM
  #529
Admit you filled the shocks with helium to get it that low... Mine is 1671
rhodopsine is offline
Old 12-11-2015, 03:07 PM
  #530
trf415msx's Avatar
Trader Rating: 24 (100%+)
Mine 1748 g it too heavy you guy have indoor clay setup to share
trf415msx is offline
Old 12-12-2015, 12:09 AM
  #531
Sorry, no. I'm astro and carpet.
Piles is offline
Old 12-12-2015, 11:35 AM
  #532
What alu rear suspension hangers should i get for stock arms?
Z2-300RF and Z4-300SRR?
matterooth is offline
Old 12-12-2015, 12:57 PM
  #533
Trader Rating: 166 (100%+)
The Z4-300SRR.
jpcopeland1 is offline
Old 12-12-2015, 10:20 PM
  #534
HSV427's Avatar
Trader Rating: 30 (97%+)
Does any body know how many teeth the idler gear in the gear box has. TIA
HSV427 is offline
Old 12-13-2015, 05:27 AM
  #535
mes
I don't know how many teeth the YZ-4/YZ-2 idler has, but it is the same size as the B5M one if this is what you would like to know. I compared them back to back when I built my YZ-2.
mes is offline
Old 12-13-2015, 06:57 PM
  #536
HSV427's Avatar
Thanks heaps
HSV427 is offline
Old 12-14-2015, 09:46 AM
  #537
DaveG28's Avatar
Trader Rating: 65 (100%+)
Hi all,
Put mine through its paces and have a couple of queries:
1. It's terrible on jumps - noses down all the time, and requires full throttle in the air to even keep it able to land... Is anyone else finding this? I have tried moving weight as far back as possible!?
2. Struggling for rear traction... Though more toe has improved this along with weight!
3. I see there is a LOT of play in the front arm inner mounts as the inserts move in the Ali mount... Anyone finding this a problem? I added 1.5mm spacer in front before the brace but now everything has slop! I see the team guys at the Worlds had a different front brace that clamped around the chassis.
Thanks,
Dave
DaveG28 is offline
Old 12-14-2015, 10:11 AM
  #538
Originally Posted by DaveG28
Hi all,
Thanks,
Dave
For point 1&2 it sounds as though you have too much anti squat. Try looking at the rear suspension mounts. Check to see if they are the right way up and that you are using what the instructions recommend. There are parts in the kit which are not used.
Cant help with point 3. Mines not sloppy at all. Sorry.
Piles is offline
Old 12-14-2015, 10:26 AM
  #539
DaveG28's Avatar
Just on point 3 - when mounted there is about 1.5mm gap between the front brace and the front bumper - this enables the inserts to move back and forward about 1.5mm?
Thanks for the idea re. Antisquat, I am using front insert high and rear using 2ho high I think!? I could swap the front to low? My current setup is very close to kit std!
DaveG28 is offline
Old 12-14-2015, 10:39 AM
  #540
joeymdz's Avatar
Hi all,
Thanks,
Dave
I ran the stock set up for 10 laps and instantly switched to a Lee Martins setup (as close as I could get it without upgraded parts). I would go with a non stock setup route.
after 2 days of running my car had tons of drag. I took out the diffs and my front one was feeling still new. I swapped out the bevel gears for some used ones and it was a night and day difference.
might also run your belts as loose as possible.
joeymdz is offline
