Yokomo YZ-2
#4111
[QUOTE=Quietman;15269917]
battery holder is 3D printed and the gearbox is from the dirt yz2 car original
#4112
This is most probably a prototype part, just like the slipper and/or stand-up gearbox in his car, which allows putting the shocks into the front of the shock tower. Hopefully the battery brace will become available when their stadium truck hits the shelves in fall/winter. Otherwise I'd expect it to be included at the latest in the 2019 kit(s), which are likely to be released around April/May if Yokomo continue to follow the schedule of the previous years.
Edit: The plastic frames are likely the ones from the belt-drive YZ-4, part no Z4-001 with the addition of a part on top.
#4113
Servo horn
I did a search and didn’t come up with much on this. I just got a used yz-2 dtm and it has the plastic servo horn. Is everyone using the 17mm aluminum ones by Yokomo or did people find good, cheaper options? Seems like $20 shipped is a lot for a servo horn. I’d appreciate recommendations.
Edit: I found this Yeah racing servo horn with 17mm and 20mm holes: http://www.yeahracing.com/catalog/ya...ck-p-4040.html
$6.49 plus 3.49 shipping on ebay. Seems like a winner. If you have another recommendation, please let me know.
#4114
Edit: I found this Yeah racing servo horn with 17mm and 20mm holes: Servo Arm & Screw - Yeahracing - (#YA-0516BK) 25T Aluminum Servo Arm Horn For Futaba Savox Power HD Blue Bird Bla
#4116
I ordered the yeah racing one. The offset may not be as great but I think it may be close enough. I'll report back once it arrives.
#4117
Reporting back, the offset is not great enough on the Yeah Racing servo horn I linked to in a previous post. I was able to put a nut on the ball stud threads before screwing it into the horn to give it adequate offset. Doesn't look horrible, but doesn't look great either.
#4120
Can anyone tell me what it would take to convert a original yz-2 to a up to date car ? Sorry if you guys get tired of people asking this question.
#4121
There are comparison charts on petitrc:
http://site.petitrc.com/setup/yokomo...MvsDTM2vsCAL2/
http://site.petitrc.com/setup/yokomo...2/YZ2_Compare/
#4122
Tech Legend
I guess it would be shorter to list the remaining parts. Bearings, some hardware items, aluminium front bulkhead and shock bodies should still be the same. Completely updating an original 4-gear YZ-2 to CAL2 or DTM2 standard will hardly make any sense, I assume.
Yokomo YZ2 - Compare Charts
Man prices on these crash or something? just helped a buddy score a hopped up YZ2 DTM2 with very little usage for less than $200.
#4123
I am setting my new yz2 dtm2 for stock 17.5 class indoor med to high bite clay. Track size is pretty good, but what I am looking to see what clutching system is everyone using for stock. I really don't care for the eliminator, prefer the slipper system. The one that comes with kit is a 3 pad setup but I can not find a 72t 48p spur gear for it. Would I be better going to Avid or Schelle system?
#4125
Not much different, different steering rack, bigger rear diff case, different motor plate and some shims for the rear bulkhead, then the bigger ball studs. I updated, and really only got the different steering rack, had the motor plate but on our track there was NO difference, so I sold the rear shims and motor plate to someone that "had" to have it ( I am still faster lol) will order the bigger diff case but only when I need to change my diff oil. With me running the yz4sf and it came with the smaller ball studs there was no need to upgrade the ball studs as I would then need to have two sets one for the yz2 and one for the sf. Other things are the front gullwing arms and shock tower but I assume you might have already upgraded those, along with the rear hubs.
